Max-on - I'd question the reason behind it. Yes, you get some increased breaking strength and decreased stretch and save some weight, but from what I understand - you pay A LOT for that. For safety (inspection) reasons I think I'd pick it over rod, but only if I was putting together an offshore racer and had a reason to pay the extra money.
s/v "Pelican" Passport 40 #076- Preparing to cruise - http://blog.svpelican.com
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
Labatt, you may have not understood by question; the rigger recommended standard wire, I asked him about dyform, and he said it was not worth it. I was in a rush and late for an appointment that day and did not have time to inquire as to why, so I was curious as to the reason for his response. I did not know dyform is 'so' much more expensive, that is probably the reason for his comment.
SD,
If they weren't invisible, then the scores of impaled sailors with bloodied body parts, must all be blind.
Sailingdog Telstar 28
If you're new to the Sailnet Forums... please read this POST.
I know that you were being facetious. but as you get older, the eyesight starts to go...
Originally Posted by TrueBlue
I was being ficitious SD, just as "no-see-ums" can be seen, but usually only after you swat them dead against your biten skin.
I never said you were aging... any inferences you make are completely your own...
The big thing about rod is that it has a much longer lifespan and is actually more reliable and easier to inspect. It also offers significant reduction in stretch for a given weight, strength and diameter.
Most wire rigging failures are at the terminals. Its true that with really shot wire rigging you get a meathook, but typically long before the meathook shows the wire has lost its strength.
