01-09-2008
Originally Posted by max-on
With all the benefits and versitility a frac rig offers, why are not all modern cruisers, say 40-50 ft, designed with a frac rig instead of a masthead rig, especially as most cruisers are a couple?
Good question, Max...
In fact, several manufacturers are leaning towards fracs, such as Hanse and Bavaria, some Hunters but in some cases the "I" measurement is such that they are 15/16 rigs or greater... one has to wonder if there's any real "advantage" at that stage.
I think in general the typical masthead rig is perceived as a more robust arrangement, less "tweaky" and many cruising sailors favour ruggedness and stability over performance enhancing strings to pull.
As mentioned earlier, the really tweaky rigs that require careful and constant attention to running backstays and checkstays is just too labour intensive for most. However there certainly are plenty of fractional rigs (ours included) that do not rely on such arrangements.
Another factor is that the mast clearance tends to be lower as the frac needs a taller rig to achieve the sail area since the headsails don't provide as much. Mast clearance is a big issue for East coast boaters on the ICW.
To some, I think any frac rig is percieved as a racing one, and may be rejected out of hand by some cruiser types.
1984 Fast/Nicholson 345
