Fractional Rig vs. Mast Head Rig - Page 6 - SailNet Community
Blogs
Go Back   SailNet Community > General Interest Forums > Boat Review and Purchase Forum > Sailboat Design and Construction
  #51 (permalink)
Old 01-31-2008
Gary M's Avatar
Gary M is on a distinguished road
As Plumper says the jumper struts are to keep the top of the mast above the hounds from bending too much. What this does is allows the backstay to tension the forestay on a fractional rig just like it does on a mast head. With out them the portion of the mast where the forestay is attached may move forward which relaxs your forestay right when you do not want it to.
I had a 26 foot fractional about 7/8 I think. It had the spreaders angled back about 25 deg. and you had to tighten the hell out of them to get some reasonable tension on the forestay.
I really did not like this arrangement, there was always, even at the dock a huge force on the chain plates and rig. I just could not get my forestay flat enough to have decent performance upwind in heavier air.
I changed my spreaders to have only about 5 deg of swept back and put jumper struts above the hounds. Made a huge difference up wind and I could now ease off on my back stay and relax the rig down wind.
With a perfomance fractional rig you can learn a lot about tuning a rig and shaping a main.
I now sail a masthead 30 footer with a large main which I am very happy with, well except for the cost of head sails.
Gary
  #52 (permalink)
Old 03-06-2008
OutThere is on a distinguished road
Can someone tell me if the jumper struts on a fractional rig keep the mast from working for and aft in a sea way?
Are these struts necessary on a mast with a permanent back stay?
  #53 (permalink)
Old 03-06-2008
Plumper's Avatar
Sailor
Plumper is on a distinguished road
What kind of rig is it? on what boat? The rig should not work fore and aft (pump) at all. Many big frac rigs have check stays or runners to prevent this, but not all do. It depends on how the lowers are rigged. The jumpers keep the top of the mast in column when tension is put on the backstay. The middle may come out of column if the shrouds are all athwartships of the mast (none run slightly aft). In that case there should be a baby stay or check stays to prevent pumping.
There is a tide in the affairs of men,
Which, taken at the flood, leads on to fortune;
Omitted, all the voyage of their life
Is bound in shallows and in miseries.
Shakespeare, Julius Caesar IV, iii, 217
  #54 (permalink)
Old 03-07-2008
bob chaisson's Avatar
Wharf Rat
bob chaisson is an unknown quantity at this point
Post
Just a quick quote, "The masthead sloop has established itself as most yachtsman's rig of choice. Equally clear is the reason for its popularity: it's simple and uncomplicated." Peter Hahne; Sail Trim Theory and Practice
One hand for the helm, one elbow for yourself!
  #55 (permalink)
Old 03-07-2008
Jeff_H's Avatar
Super Moderator
When was that written?
  #56 (permalink)
Old 03-07-2008
lharmon is on a distinguished road
We have a 30 foot masthead sloop. It is an easy boat to sail. The jibs are roller furled. We usually select either a 150% genoa or a 110% jib and use that sail for the day. By choosing the right headsail we usually do not need to try to sail with the headsail furled any. We frequently change the sail on the furler to match the conditions.
Our boat is stiff so the main reefs at 22-25 knots and the second reef is needed at 35 knots. at that point the 110% jib is a liability and is furled up a bit. We have good control. As it starts to deterrioriate or we get gleeful from our speed we reef. It is simple and works for us.
It's better to have your enemies inside your tent pissing out than outside your tent pissing in...
  #57 (permalink)
Old 03-07-2008
Wharf Rat
Lightbulb
First published 2001 in Germany, english edition published 2005. Small book with lots of good information. Hahne is very level headed with a turn of humor. A heck of a value at 20 bucks american.
  #58 (permalink)
Old 03-08-2008
Jeff_H's Avatar
Super Moderator
Bob,
"Equally clear is the reason for its popularity: it's simple and uncomplicated."
That strikes me as a very strange statement. There is nothing simplier about a masthead rig than a fractional rig. Arguably with a masthead rig's need for forward lower shrouds a fractional rig is actually simplier to build, maintain and tune.
I also disagree that the masthead rig is the most popular rig being produced today. If you look at the majority of new sloop rigged being produced at this time, fractional rigs are far and away more common. The one thing that has prevented a bigger switch to fractional rigs is the popularity of inmast furling which is a bit harder to do on a fractional rig, although Hunter, Beneteau, Hanse, Tartan and Bavaria have found a way to make it work.
  #59 (permalink)
Old 03-08-2008
Wharf Rat
You appear to have failed to notice that it was a quote from Peter Hahne's Sail Trim: Theory and Practice. I cannot in good concience reproduce the entire chapter Rig Trim, Pages 49 - 55, but I highly recommend the read. He makes a good case for his statement.
  #60 (permalink)
Old 03-08-2008
BWAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA
THIS THREAD IS FUNNY
Should be in the Off Topic
Sloop, Cutter or Ketch jsgsail Boat Review and Purchase Forum 17 12-26-2008 03:47 PM
New to Sailing, please Help =) xyris Learning to Sail 19 11-17-2008 09:30 AM
Ketch/Yawl Handling svsymphony Seamanship 19 07-05-2008 02:19 AM
Sloop or Ketch? maxheadspace Boat Review and Purchase Forum 46 07-27-2007 03:56 PM
Yawl Info Needed sailortonyb1 Boat Review and Purchase Forum 5 01-18-2006 05:51 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
