Blogs
Go Back   SailNet Community > General Interest Forums > Sailboat Design and Construction
User Name
Old 01-06-2008
stm stm is offline
stm is on a distinguished road
jib and reacher design
I am considering a boat with slight fractional rig that carries a 100% self tacking jib. Along with that there is a roller furling reacher for off wind/ light wind work. Seem like the perfect senario to me , who almost always will be single/shorthanded. Any thoughts?
Old 01-06-2008
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
Sounds like a great setup for what you're describing. what kind of boat is it??
If you're new to the Sailnet Forums... please read this POST.
Old 01-06-2008
Idiens's Avatar
Idiens Idiens is offline
Larus Marinus
Idiens is on a distinguished road
A light weight reacher might be a little weak for cruising long range, where one might hope for many weeks of reaching and down wind work.
Jonathan-Livingston
Old 01-06-2008
I get the feeling he's coastal cruising, weekending or daysailing, not sailing the tradewind routes. That said, yes, if he wanted to do the tradewind routes, then a heavier light-air sail would be a good idea.
Also, some boats don't go downwind all that well, since they can roll and pitch and otherwise end up handling pretty squirrely.
Old 01-06-2008
Idiens's Avatar
Larus Marinus
Yes, for coastal stuff, he has a good GP combination of foresails. That self tacker will work well in narrow passages.
Tacking down wind is one trick to avoid rolling about. But the multi-hull guys need not worry about that, I guess.
Jonathan-Livingston
Old 01-06-2008
Yes, but most multihulls, including mine, are actually faster if they tack downwind... since they can go faster if they're on a broad reach than they can usually going dead downwind. But they don't get all wallowing and rolling like the monohulls do.
Old 01-06-2008
stm stm is offline
Mostly Chesapeake Bay Cruising , Tartan 3400
Old 01-06-2008
JohnRPollard's Avatar
JohnRPollard JohnRPollard is offline
Sailor
JohnRPollard has a spectacular aura aboutJohnRPollard has a spectacular aura about
STM,
This can be a very good combination for how most people cruise their boats (i.e., coastal). Most racers would want more flexibility, but this arrangement is not usually offered on flat-out race boats. The mainsails on these boats tend to be larger to provide much of the drive upwind, with the smaller jib helping out. And then you get to "switch gears" for the downhill leg and quickly spread more canvas.
Saga and Tartan offer this headsail combination, and I've heard generally positive feedback. Personally, I wouldn't mind this set-up at all, although I wouldn't necessarily insist on the self-tacking aspect. Also, it generally works better when the downwind sail is tacked at the end of a longish fixed sprit, but most designers and builders seem reluctant to use long fixed sprits nowadays. About the most you'll see is an extended anchor platform.
I think Tartan calls theirs the CCR for "Cruise Control Rig" (which sounds a bit silly to me), and I really like their new 4300 on which it's offered. I think it's also available on their 3400, maybe some other models as well.
Edit: Ah, I see you posted the boat model while I was typing. I think that would be an almost ideal sail combination/boat for cruising the Chesapeake. Lucky you.
Old 01-06-2008
7Psych 7Psych is offline
7Psych is on a distinguished road
Our Tartan 3400 is currently in the process of being built. We have a late January/February delivery date and we could not be happier. We have the centerboard version as our sailing in Barnegat Bay in NJ is extremly shallow. We considered MANY boats, did our homework, and finally setteled on the Tartan. This will be our second Tartan...We also had Tartan 10 and raced for many years. Please fell free to PM me if you would like any other info...
Dale
Old 01-06-2008
Sailor
7Psych,
Tell us about the centerboard. Is this the only shoal draft option for the 3400, or is there a beavertail offered? Draft specs appreciated...
Display Modes
vB code is On
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
