01-06-2008
Moderator
Originally Posted by 7Psych
The boat is offered the three keel configurations. Fin Keel-6'6", Beavertail-4'11", and Keel/Centerboard-3'11"/7' board down. The keels are all interchangeable. If I decide to change to the deep draft keel, all I do is just order it and essentially replace the Keel C/B and bolt it into place!
Interesting. On the Chesapeake I could easily get away with the beavertail (but not if I owned a shallow-draft dock), although the centerboard version would also work. That's clever that they made the keels interchangeable. If enough are built, I can see an owner's group at sometime in the future with a bulletin board for "Keel Swapping".
Back to the original topic, did you order the CCR? Why or why not? Or is that the only option on the 3400?
