Blogs
Go Back   SailNet Community > General Interest Forums > Sailboat Design and Construction
User Name
  #11 (permalink)
Old 01-07-2008
hellosailor's Avatar
hellosailor hellosailor is offline
hellosailor will become famous soon enough
I'm with sd on that one, it IS a steaming light, even if someone hooked it up to a switch that says "anchor light". When you've got an obstruction in the middle of the boat--whether it is a big thinkg like a pilothouse or a thin tall one like a mast--you need to get the anchor light all the way above the obstruction to meet COLREGS.
  #12 (permalink)
Old 01-07-2008
SVDistantStar's Avatar
SVDistantStar SVDistantStar is online now
'72 Pearson 36
SVDistantStar is on a distinguished road
Send a message via AIM to SVDistantStar
On my Pearson ive got a Davis Megalight attached about 1/4 the way up the backstay. The only downside is i cant seem to keep a battery long enough for it to stay powered.
  #13 (permalink)
Old 01-07-2008
uspirate's Avatar
uspirate uspirate is offline
Trim for Sail
uspirate has a spectacular aura aboutuspirate has a spectacular aura aboutuspirate has a spectacular aura about
USP-
Are you sure it is an anchor light, and not a steaming light?? I can't see how it would qualify for 360˚ visibility if it was mast mounted.
Most of the time an anchor light is not mounted on the masttop, it is on a small post or hanging from the rigging.
oh yeah, sorry U B right, it is a steamer!
To get the most from Sailnet, read the post in SD's signature.
Sin City, Liquor all day, Poker all night...Lake Mead & Channel Islands, So Cal
BJ & Nimfa
S/V Komona Wanaleia
Las Vegas Boat Harbor cam
  #14 (permalink)
Old 01-08-2008
66luders's Avatar
66luders 66luders is offline
66luders is on a distinguished road
thank you all for your input. I suppose it will be best to keep an anchr light on the top of the mast. I wanted to rewire the ancor light, steaming light and vhf antena... but i have just about decided against it after discovering how difficult it is. That is why I thought it would be nice to just put the anchor light and vhf on the stearn with the radar and wind generator.
  #15 (permalink)
Old 01-08-2008
sailaway21 sailaway21 is offline
gadfly
sailaway21 is a jewel in the roughsailaway21 is a jewel in the roughsailaway21 is a jewel in the roughsailaway21 is a jewel in the rough
The anchor light should be well up the mast or high in the rigging, else you'll not get your maximum visibility of it. From reading the Colregs one can see the value of what they call deck illumination, required on ships at anchor, and this could be your spreader lights or other lighting.
A solution for all-round visibility, should you wish to mount the anchor light to the mast but not place it atop the truck, is to use two lights of 180 degree arc each. They can be mounted to either side of the mast, at the same height, and thereby offer you an almost infinite range of placement. From a distance, even a short distance, they appear as one light. You'll commonly see this on ships and tugs where the mast is quite substantial and it is otherwise impossible to get the all-round pattern required.
I'd not be anchoring where a sailboat would want to have an aircraft warning light. In another life I spent a nerve-wracking two days at Castle Island terminal in Boston, which is right in the landing path of the jets comeing into Logan International. Wondering if those 747's were going to clear the ship's masts is not a good way to get a restful sleep, regardless of the knowledge that they've been clearing them for years. All that matters is that they don't look like they're going to clear and they sure didn't sound like they cleared by much either. Deer in the headlights pretty much describes my two nights alongside.
If waterboarding was a sexual preference they'd be teaching it in schools.
  #16 (permalink)
Old 01-08-2008
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
The turbulence off the planes along Logan's Boston Harbor side can play havoc with small sailboats too.
—Captain Malcolm Reynolds, Serenity (slightly edited)
If you're new to the Sailnet Forums... please read this POST.
  #17 (permalink)
Old 01-08-2008
Boasun's Avatar
Boasun Boasun is offline
Boasun will become famous soon enoughBoasun will become famous soon enough
Run a Coleman lantern about 2/3 of the way up your fore-stay That will work and you will also have a well lit deck also. and be legal also. It don't have to be at the top of the mast. That is just a convenient place to put the thing and have it out of the way of other electrics.
Oh keep your steaming light right were it is at. You need it when under power.
  #18 (permalink)
Old 01-08-2008
c130king's Avatar
c130king c130king is offline
c130king is on a distinguished road
What is the definition of "designated anchorage"?
I mostly day-sail, but would like to start doing some overnight/weekend trips to include anchoring. And, since I am almost always well inland, I don't use a chart...
...which is where I imagine the anchorages are "designated".
And I don't have an anchoring light...only a steaming light.
Thanks,
Jim
  #19 (permalink)
Old 01-08-2008
camaraderie's Avatar
camaraderie camaraderie is offline
Moderator
camaraderie has a spectacular aura aboutcamaraderie has a spectacular aura aboutcamaraderie has a spectacular aura about
C130...yes...designated anchorages are identified on the charts. Generally in a purple outlined area. In such areas, no anchor lights are necessary and other boats are forewarned about cutting through such areas at night.
Tayana 52 Ketch
  #20 (permalink)
Old 01-08-2008
C130King-
You really should be using a chart, even inland... there are hazards to navigation inland as well as coastal. Also, without an anchor light, you'll need to know where the designated anchorages are, and without a chart, you'll be hard pressed to find one.
Display Modes
vB code is On
Battery Location kidg Gear & Maintenance 1 08-06-2007 06:42 PM
Coast Guard finds debris near last known location of sailboat - Boston Globe NewsReader News Feeds 0 06-16-2006 07:15 PM
Debris Found Near Last Known Location Of Missing Sailboat - Boston Channel.com NewsReader News Feeds 0 06-16-2006 02:15 PM
General comment about classifieds here - boat location? mikej2 SailNet Website Technical Support 6 05-05-2006 10:11 AM
Location, location, location!!! newuser Living Aboard 4 10-24-2002 09:25 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
