it's not a sailboat but... - SailNet Community
Blogs
Go Back   SailNet Community > General Interest Forums > Boat Review and Purchase Forum > Sailboat Design and Construction
Old 01-14-2008
chucklesR's Avatar
Gemini 105Mc Hull 987
chucklesR is a jewel in the rough chucklesR is a jewel in the rough chucklesR is a jewel in the rough
Navy Seals got a new Mako designed and built for them because the current one puts up to 20g of force on the passengers as it slams along at 50+kts Despite shock absorbers on the seats).
To reduce the pounding transmitted through the now aluminum hull they went with kevlar and foam, and I'm sure more tax dollars went into that - making the boat stiffer and lighter I guess.
- don't they know that the hull design itself is the best place to reduce pounding? And to make it lighter they could go with gas vs diesel, or even turbine (since they aren't paying for fuel and this isn't a long range vessel).
http://www.cnn.com/2008/TECH/01/13/s....ap/index.html
Old 01-14-2008
tomaz_423's Avatar
tomaz_423 will become famous soon enough
I am not a naval architect, but I would guess that the stiffer the hull is the more G force will be put on the crew when it hits the wave and not less.
I would rather go to different shape of the hull: Sharp V or some sort of wave piercing design.
The other could be to have long (collapsable?) wings down in the water and glide above the water like some fast ferries.
Chuck, if they do build them please remind them to send me 1% for my idea. :-)
Beneteau Oceanis 473
preparing to sail away
Old 01-14-2008
2Gringos's Avatar
2Gringos is on a distinguished road
I can see several reasons they would prefer diesel to gasoline.
Two Americans move to the TCI.
Old 01-14-2008
Jeff_H's Avatar
Super Moderator
The idea is if you can reduce weight you can reduce pounding forces. Carbon/Kevlar/ high density foam produces a substantially stronger-tougher hull with less weight than aluminum or steel. In the current marketplace, both carbon fiber and kevlar has gotten relatively cheaper especially as compared to years past, so the choice to use kevlar may have partially been cost savings driven.
Respectfully,
Old 01-14-2008
Kevlar isn't all that good at producing a stiff hull...since it is weak in compression, but strong in tension—can't push on a rope after all.
The main benefit and reason kevlar is used in laminate hulls is for impact resistance. If it is used as part of the inner laminate, in the case of an impact, the outer hull and foam will often be damaged, but the inner laminate will flex, but not break, preventing the boat from taking on water.
A properly engineered fiberglass/carbon fiber/kevlar/foam composite laminate hull will be very, very tough and light. It also will have the added advantage of absorbing noise and vibration in many cases, especially compared to a steel or aluminum hull.
Sailboat cost vs Powerboats Fishboat Boat Review and Purchase Forum 19 09-28-2010 12:38 PM
C&D Canal reopened following sailboat crash - NEPA News NewsReader News Feeds 0 05-16-2007 11:15 AM
Search continues for missing sailboat, crew - Charlotte Observer NewsReader News Feeds 0 05-12-2007 05:15 AM
1 body washes up as about 100 migrants in sailboat reach Florida - WHDH-TV NewsReader News Feeds 0 03-29-2007 01:15 AM
Large-scale search for sailboat continues - Newport Daily News NewsReader News Feeds 0 06-18-2006 07:15 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
