Blogs
Go Back   SailNet Community > General Interest Forums > Sailboat Design and Construction
User Name
Old 03-30-2008
northstarjim northstarjim is offline
northstarjim is on a distinguished road
new v berth
I would like to install a v berth in my Northstar 500. Currently there is a head just forward of the main cabin, then about 6 feet of empty space in front of that. How would I go about installing the framing/etc without drilling holes in the hull? Any other tips/ ideas???
Old 03-30-2008
camaraderie's Avatar
camaraderie camaraderie is online now
Moderator
camaraderie has a spectacular aura aboutcamaraderie has a spectacular aura aboutcamaraderie has a spectacular aura about
You can glass the wooden framework to the hull with fiberglass tape and resin. You might even get by with a strong adhesive like 3M 5200 to bond the wood to the hull. If I were doing it, I think I would construct 2 or 3 upside down trapezoid shaped frames to fit the hull shape and bond them in place so that the frame itself bears the weight rather than your hull to wood bond. Top off with epoxy sealed marine plywood in a V berth shape and maybe cut out an access hatch so you have storage underneath.
Tayana 52 Ketch
Old 03-30-2008
Faster Faster is online now
Just another sailor
Faster will become famous soon enoughFaster will become famous soon enough
You'll probably want to install at least a partial bulkhead as well to support the end of the berth platform, and this can be done by the normal tabbing method. You will need to grind down to fresh glass to get as good a bond as possible.
Also Epoxy resin is going to get you a better secondary bond than polyester, but that precludes using matt, you'll need to use cloth or roving.
Do some very careful measuring first... you say you have "about 6 feet" of empty space.... make sure that what you end up with will actually sleep a couple of adults. The further up the boat the berth is, the narrower the foot space and that makes for more conflicts in the middle of the night.
Add a more complete bulkhead and you may be able to add a hanging locker across from the head if you don't have something there already.
Good luck, keep a hatch open while you're working! It goes without saying that dust masks, paper coveralls etc are mandatory.
Boating in BC waters since the '60s, sailing since 1981.
Currently on our 5th boat, a 1984 Fast/Nicholson 345.
Old 03-30-2008
soulesailor's Avatar
soulesailor soulesailor is offline
blue collar cruiser
soulesailor is on a distinguished road
Installing partitions and partial bulkheads to the hull requires a complex curve cut. Look up the 'tick-stick' method on how to transfer the shape of your hull to the plywood. It's not difficult, just a little hard to describe without pictures.
Voice or no voice, the people can always be brought to the bidding of the leaders. This is easy. All you have to do is tell them they are being attacked, and denounce the pacifists for lack of patriotism and exposing the country to danger. It works the same in every country.
-Hermann Goering, Hitler's Reich-Marshall
Nuremburg trials
Old 03-30-2008
Just another sailor
Good point, Soulesailor... Bruce Bingham's "A Sailor's Sketchbook" has an excellent page on using the tick stick.
The book is worth owning on many other levels too.... Especially for someone thinking of a project like the OP has in mind.
Display Modes
vB code is On
An all-purpose settee berth GoodOldBoat Gear & Maintenance 0 12-06-2007 08:51 AM
Goodbye bed, hello storage GoodOldBoat Gear and Maintenance Articles 0 05-14-2007 08:20 AM
Baby gate for the vee berth? Jotun Cruising 13 04-22-2007 07:05 PM
Diesel fume barrier for master berth? mikeedmo Gear & Maintenance 5 12-29-2006 06:15 AM
27'' with long vee berth? mrb2222 Buying a Boat 8 06-07-2002 03:01 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
