Go Back   SailNet Community > General Interest Forums > Boat Review and Purchase Forum > Sailboat Design and Construction
  #11 (permalink)
Old 02-06-2008
Another reason I suggest the one-boat approach is that even if you don't lose money selling the first boat to buy the second on the boat itself, you will almost definitely have lost the money you spent on outfitting the boat. By buying a single boat that is well suited to handling both your short-term and long-term sailing plans, you won't risk losing money selling it to buy a second boat, and won't have to out fit it twice. The fact that you'll only have to learn one set of boat systems--engine, head, electronics, rigging--is a huge bonus.
  #12 (permalink)
Old 02-06-2008
camaraderie's Avatar
moderate?
The sounds of NC ad the ICW call for a shoal draft boat if you are going to be sailing rather than mmotoring in channels. You will need to get something with 5' or less draft or a centerboarder where the board can be raised to allow 5' draft. Your initial budget. Your budet eems to be under 100k from the boats you are looking at which is CHEAP for a 40' blue water boat...and any 40' blue water boat you find for under 100k will need a good deal of work to be ready for sea.
Much of what you want to do would be considered coastal/caribe cruising which does not require a blue water boat...only the portions heading north of Southern Cal. and across the Atlantic or Pacific would be within my definition of "needing" a blue water boat.
I agree with the notion of buying one boat suitable to your goals and learning on it.
So...I would suggest you consider:
1. Altering your budget to around $150k
2. Getting a smaller bluewater boat with shoal draft.
3. Altering your cruising plans a bit to allow for a coastal cruiser in the size you want.
Safety of Edel Cat 35 as a blue water cruiser? flyfisher General Discussion (sailing related) 22 01-22-2008 03:15 PM
Blue Water Capable sab30 Boat Review and Purchase Forum 20 08-30-2007 09:11 PM
Blue water cruising boats xnavyx2 Boat Review and Purchase Forum 18 12-30-2006 05:58 PM
Shoal Keel and blue water? acmecoyote General Discussion (sailing related) 8 10-15-2003 11:48 AM
Best Keel for Coastal and Blue Water Cruising halsmithjr Boat Review and Purchase Forum 24 04-10-2001 09:03 AM
