Go Back   SailNet Community > General Interest Forums > Boat Review and Purchase Forum > Sailboat Design and Construction
Old 03-05-2008
S/V PARAGON
ericfremont is on a distinguished road
New Wauqueiz hull construction
Been looking through literature on new Wauiqueiz's (e.g., PS 47, PS 43, etc.). They indicate their hulls are cored and vacuum infused, but there is no specificity with respect to core materials below waterline. Does anybody know if they're building with the core materials below waterline?
Old 03-05-2008
SailorMitch's Avatar
Senior Moment
SailorMitch will become famous soon enough
You'd be better off asking this question from a Wauiquiez dealer I think, or find their website. One place to start is Annapolis Yacht Sales Beneteau, Sabre, Wauquiez, Alerion Yachts Brokerage Service
SailorMitch
Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
Old 03-05-2008
From their website, all it says is:
THE HULL is laid up with the greatest of care, and bisphenolic resins in the outer layers help protect your boat in the long run. Today, Wauquiez also uses the « infusion » process, which not only helps protect the environment, but also ensures an optimum resin /glass-fibre ratio, as well as an exceptional stiffness (balsa sandwich) and important weight savings.
Since they don't specify not using the balsa sandwich below the waterline, I would guess that the hull is cored. Most builders will specify if they don't use core materials in the hull below the waterline.
Old 03-05-2008
camaraderie's Avatar
moderate?
You can bet they would say it if coring stopped at the waterline.
Old 03-05-2008
My boat is cored under the water line above the water line, on the deck, inside and outside....the only part not cored is a foot wide strip runing from the bow to the stern along the boat's lenght...I don't see my cored hull being a problem...
Old 03-05-2008
tomaz_423's Avatar
tomaz_423 will become famous soon enough
Giu, but your core is not balsa and does not rot.
Beneteau Oceanis 473
preparing to sail away
Old 03-05-2008
GySgt's Avatar
Semper Gumby
GySgt is on a distinguished road
Send a message via MSN to GySgt
You mean Giu is not rotten to the core, huh, he must be a good guy
I like pigs. Dogs look up to us. Cats look down on us. Pigs treat us as equals.
Sir Winston Churchill
Old 03-05-2008
ahhh
Sorry my bad...I didn't understand they were balsa, I thought they were PVC in these days and age..
Old 03-05-2008
chucklesR's Avatar
Gemini 105Mc Hull 987
chucklesR is a jewel in the rough chucklesR is a jewel in the rough chucklesR is a jewel in the rough
Nothing wrong with a marine plywood, epoxy saturated, fibreglassed core - as long as you know what you are dealing with and don't puncture it. That's what my decks are - hull is solid glass.
Old 03-05-2008
The problem is that they're French boats.
C & C 121 Customer Response to Manufacturers Post camaraderie Tartan 0 09-10-2007 06:43 PM
High Tech vs traditional-Comments? Pangaea General Discussion (sailing related) 38 08-07-2007 01:07 AM
Hull Construction Questions Dan Dickison Gear and Maintenance Articles 0 01-15-2001 07:00 PM
