03-05-2008
IMHO, it won't be very good for a template, since an old used sail will be a bit stretched out and mis-shapen compared to the shape you'd ideally want for a new main sail. It would be close, but you'd probably have to adjust the panels a bit to get the original shape, unless your old mainsail is in relatively good shape.
