I—distance between top of forestay and the foredeck
J—distance from forestay chainplate to mast
P—distance from boom to top of mast
E—length of boom
Mainsail area is approximately (P * E)/2. This is only approximate, since most main sails are cut with some roach.
Jib area is approximately (I * J)/2. This is also only an approximate because some
jibs are cut with a high clew, to help the helmsman see under the sail or other slight modifications.
Here's JRP's Link :
LINK
JRP... the forum autolinking keyword software is screwing you up.
POST.
