Long versus short overhangs - Page 4 - SailNet Community
Blogs
Go Back   SailNet Community > General Interest Forums > Boat Review and Purchase Forum > Sailboat Design and Construction
  #31 (permalink)
Old 03-15-2008
Valiente's Avatar
Originally Posted by TrueBlue View Post
Val, Aren't you at all concerned about your boat toppling off her stands, storing it on a steeply sloped hillside like that? (g)
No. The problem always goes away when I sober up.
  #32 (permalink)
Old 03-15-2008
Valiente's Avatar
Originally Posted by SailorMitch View Post
I love reading Ted's stuff -- clear and to the point. I use his website fairly often when doing research because of his plain English explanations of boat design elements.
He seems happy to respond to e-mails as well, particularly to expand on the discussions his articles begin.
And he drew some excellent ocean boats, as did his former partner, Bob Wallstrom.
  #33 (permalink)
Old 03-15-2008
speciald's Avatar
Special Delivery
speciald is on a distinguished road
Send a message via Skype™ to speciald
I would think that plumb bows have the advantage of increasing the waterline length for a given LOA but decrease the reserve boyancy of the bow, decreasing a boat's ability to rise over a wave rather than plowing through it.
  #34 (permalink)
Old 03-15-2008
Jeff_H's Avatar
Super Moderator
"I would think that plumb bows ...... decrease the reserve boyancy of the bow, decreasing a boat's ability to rise over a wave rather than plowing through it."
It completely depends on the shape and flair of the plumb bow and the amount of flair that occurs above.See my explanation of that point above. If the deck plan was the same as that of the long overhang boat, the short overhang boat could actually have more reserve buoyancy and be more capable of rising, and with a gentler motion.
I thought that it might help if I posted a couple examples of designs which have plumb or near plumb bows and which have an abundance of reserve buoyancy. A few that come to mind include the Thistle, Jet 14, J- 120 and Aerodyne 38.
  #35 (permalink)
Old 03-15-2008
Lbjordal is on a distinguished road
Well, some modern ships have. Supposedly much better at keeping speed in rougf weather
Originally Posted by Plumper View Post
So how do you explain the fact the ships aren't built with plumb bows? At what point does the traditional overhanging bow become correct again? 30', 50', 100'?
I suggest that if everything you say here is true then modern ships (especially warships) would have plumb bows and sterns. We know the age of the Dreadnought is long over.
Specifically, the negative trend toward CCA boats was because they were designed to fit a racing rule instead of seaworthiness, so many aspects of the design contributed to their poor seaworthiness not just overhangs. Contrary to your argument, most of todays offshore cruisers do have overhangs. They are not as big as more traditional designs but they are there. The overhang provides a drier ride not a wetter one. It is plumb bowed boats that have a tendency to drive through the waves rather than over them.
Regarding your claims of L/D ratios, your assumption that if the waterline length approaches the LOD then the L/D drops making it a boat as safe as an older boat with a higher L/D is flawed. The point is that as the boat with the shorter water line length (and consequently higher L/D) gets over run by a wave, the extra boat above the waterline comes into play and lifts the bow up. There is a reason why submarines don't have long overhangs.
The real reason some modern boats are built with plumb bows is for boat speed and interior room. A plumb bow boat better meets the demands for "Floating Condos" in a shorter hull than does the boat with graceful overhangs. They are also faster with longer waterlines. Proper modern bluewater cruisers still have overhanging bows if for no other reason than to prevent the anchor from flailing the hull and to sweep aside that log that you don't see....
  #36 (permalink)
Old 03-16-2008
Valiente's Avatar
That picture reminds me of the Dreadnought battleships of the 1910s and of the "whaleback" freighters of the Great Lakes 20 years previously.
There's not a lot of new ideas, just fresh attempts with different tools.
  #37 (permalink)
Old 03-17-2008
Johnrb is on a distinguished road
With respect to overhangs, this is an interesting example:
"Sea trials have been carried out of one of the most unusual motor yachts ever built. Project SF99 was designed by French designer Philippe Starck and, with its axe bow and small superstructure, bears a marked similarity to advanced stealth warships."
"The futuristic yacht, originally known as Project Sigma, is 118m long and was built in Kiel at the HDW shipyard, part of ThyssenKrupp Marine Systems. Although the identity of the yacht's owner has not been revealed, there has been speculation that it may be a Russian businessman, possibly Andrei Melnichenko or Chelsea FC owner Roman Abramovich."
http://www.sailinganarchy.com/fringe/2008/Sigma.jpg
Yachtspotter.com - News & Forum
Sigma (SF99) launched! - New Launchings - SuperyachtTimes.com
It sure is different.
  #38 (permalink)
Old 03-17-2008
randy capedory 25d seraph
rtbates is on a distinguished road
Originally Posted by Jeff_H View Post
Obviously you have not been reading my comments. If you go back to yacht design texts, working water craft histories and cruising books that predate the CCA era, there was a strong concensus that the CCA driven narrow beam, and long overhang designs have no place offshore. If you read CCA era design critiques, there was a real outcry against CCA type boats as being 'unwholesome' for offshore work. If you read some of the post Fastnet research and some of the pre- CE directive research on suitable offshore vessels, the short waterline lengths and long overhangs come into the crossfire for their negative impact on motion comfort, lack of stability, and poor carrying capacity.
At least amoung the current crop of offshore vessel designers there seems to be a near unanimous sense that long waterline/ short over hangs are the way to go from all perspectives; ease of handling, sea keeping, motion comfort, carrying capacity, not to mention overall performance.
Which also brings up a related issue. When you look at idealized values for such surrogate formulas as L/D, Motion Comfort Index, and Capsize Screen Formula, the numbers that we all are used to were based on CCA era short-waterline, long overhang designs.
If you look at an equal length on deck boat from the CCA era vs one from today, you'd be surprised that the overall weights of these boats are not all that different, but the waterline lengths of the newer boat is typically as much as a third longer than those of the CCA era boat. The newer boats also often have greater depth and higher ballast ratios as well, meaning lower VCG's relative to the Vert center of Buoyancy)
What this 1/3 longer waterline does is make the equal weight modern boat seem overly light (in other words, what we would consider a moderate displacement boat of today with an L/D of 170 would be the same weight and length on deck as a CCA era boat with an L/D of roughly 350 which would have been considered quite heavy)
Historically a LD of 170 would be considerd too light for offshore work, unable top carry adequate supplies, and the other formulas would suggesting less stable/ seaworthy, and prone to a less comfortable motion, when in fact the longer waterline/equal weight boat should actually be less prone to capsize, have a more comfortable motion and have greater carrying capacity.
But beyond that these CCA era almost by necessity are sailed at very high heel angles, and compared to more modern designs tend to scoop up a whole lot of water over the bow and be pooped over the stern making them miserable to sail in heavy going.
It is for that very reason that I cringe whenever I see someone suggest that boats like the Alberg's, Ariels, Bristol 32 and to a lesser extent 40, Triton, Vanguards and the like make any sense of offshore work.
Respectfully,
Albergs are NOT offshore worthy????Good thing all those folks sailing oceans in Alberg 30 don't know this!
Huh???
  #39 (permalink)
Old 03-17-2008
Valiente's Avatar
John Williams ripped off Wagner, so I guess Starck can rip off Lucas:
  #40 (permalink)
Old 03-18-2008
triton185 is on a distinguished road
Ted's words......
"I'll draw the line at the CCA cruiser/racer types, desirable though many of them are".
As another member has posted regarding Ted:
"He's very fond of the CCA rule and often writes of their superior seaworthy characteristics (his words).
Jeff - I have read a lot of your post and find you have a bias against vessel you perceive that fits the CCA rule.
I disagree with the general notion that boats with narrow beam, overhangs and heavy displacement are not good sea keeping boats. The CCA rule aside, boats should be taken on their design merit and nothing else.
Remembering Bill Tripp GoodOldBoat Seamanship Articles 11 06-24-2010 11:29 AM
good boat for the long run with eventual very long trips in mind AmeriCdn Boat Review and Purchase Forum 2 07-24-2007 02:05 PM
Looking to crew in Florida. Short or long term wolfbadger Crew Wanted 3 08-10-2002 03:58 AM
benefit race in the Long Beach, Ca area sailingscott Racing 0 06-18-2001 09:35 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
