Trim tab linkage for a kick-up rudder blade - Page 3 - SailNet Community
post #21 of 24 Old 08-19-2008
Yes, but a windvane requires no electricity and can keep the boat sailing more efficiently than an autopilot.
sailingdog is offline
post #22 of 24 Old 08-19-2008 Thread Starter
Given enough solar panels and a wind sensor, what would be the difference?
ClubOrlov is offline
post #23 of 24 Old 08-19-2008
bad weather, cloudy days, electrical system problems are still pretty common.
post #24 of 24 Old 08-19-2008 Thread Starter
Let's take these one at a time:
1. Bad weather. As I mentioned, my set-up dealt splendidly with very large quartering waves, too much wind, etc. The balanced rudder makes all the difference.
2. Cloudy days. Yes, you get less power from a solar array on cloudy days, but with a balanced rudder, the autopilot doesn't use up much juice at all, so you're still OK.
3. Electrical problems: if you can get 12V to the autopilot, you are still OK. If you can't, then you probably don't have nav lights either, so you aren't even legal. The Simrad stick autopilots seem remarkably robust. I broke one, so I know what it takes, and it takes a lot.
Anything else?
Building a Rudder Newport 30 Armchairprotest Gear & Maintenance 5 04-07-2009 02:11 PM
Synchronized Sail Trim Carol Cronin Racing Articles 0 03-16-2002 08:00 PM
Emergency Steering John Kretschmer Seamanship Articles 0 03-08-2002 08:00 PM
Emergency Steering John Kretschmer Gear and Maintenance Articles 0 03-08-2002 08:00 PM
Emergency Steering John Kretschmer Cruising Articles 0 03-08-2002 08:00 PM
