Blogs
Boatbldg & Repair
Galley
Hardware
Interior
Plumbing
Tlr & Wtrsprts
Videos
Go Back   SailNet Community > General Interest Forums > Sailboat Design and Construction
User Name
Old 05-10-2008
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
It amazes me that they do this.
So often, when I see people working on boats, they make the same mistakes that the manufacturer of the boat made when repairing the boat. Why would you want to do that.
A good example is in one of the recent threads where a hull support in the bilge rusted away because it was made of stainless steel. Why would you want a large chunk of stainless steel in your bilge?
IMHO, it would make far more sense to replace that chunk of stainless with a fiberglass laminate that will not be affected by the water that often is found in the bilge. Also, a steel piece up against the hull, like this piece was, will cause two hard edges that the fiberglass laminate will flex and fatigue against—where a properly installed and designed laminate support will not.
Just because the manufacturer chose to do it a certain way, doesn't always mean that is the right way to do it. Before going about a repair, I think it makes sense to take a look at what other alternatives there are and if any of them make more sense to use.
If you're new to the Sailnet Forums... please read this POST.
Old 05-10-2008
Insails Insails is offline
Insails is on a distinguished road
If it is not broke ,don't fix it..If it is broke redesign it...
Old 05-10-2008
NOLAsailing's Avatar
NOLAsailing NOLAsailing is offline
NOLAsailing is on a distinguished road
If it aint broke, don't use it...
- Jason
Rambunctious, J/30
www.rambunctiousracing.com
Sponsored Ad
Old 05-12-2008
jbibb jbibb is offline
jbibb is on a distinguished road
Bilge material
This is a very good question that brings up my situation of modifying an original design in either material or structure. I am no naval architect or engineer...I'm about to replace my steel beam at the bilge level with a coated aluminum.
Is the design intent of the original boat spec a concern? Off of the dock, who should make this call...designer has passed on...common sense or local shipwright? Right now, it's a novice me making some important structural decisions.
1974 Cal 2-29
Juneau, Alaska
Old 05-12-2008
I wouldn't use aluminum in the bilge, as it is far too vulnerable to galvanic issues if the bilge is wet at all.
Old 05-13-2008
feetup feetup is offline
seeker
feetup is on a distinguished road
I have spent the better part of the last 2 1/2 years doing a restoration of a lower end production boat that I felt had a reasonable enough design, but rather poor execution.
There is a lot of satisfaction for me to put right the places where the original builders chose to save enough to make a profit. Things like minimal tabbing of bulkheads, no sealing of structural plywood members, minimum size on fasteners, and rigging, non sealed holes in a cored deck, etc.
Often the architect had something specific in mind when he drew up the plans but the builder was forced to make a profit in a very competitive world.
The key, and a difficult key to find, is to try to analyse what the designer had in mind and rebuild it that way.
There are many places where that is extremely difficult to do, such as a suspect design or execution of a hull/keel joint, or hull deck joint. At places like that it becomes a question of worth.
Then of course there is that line between having a boat to sail, and having a boat to restore/repair.
Let's face it, even the Hinckley and the Swan's didn't do everything the best way, and let's be realistic, not every boat owner can find the formulas and do the math to plot the scantlings for a boats structural members. Probably less than 5% of boat owners can look at a structure and even hazard a guess about how strong it might be, or even what loadings it might be subject to.
For someone with hand skills, but no formal engineering training it could/should be daunting to change the basic design of a structural component, especially one that affects the safety of the rig or hull, and one that changes the materials involved. I'm not sure that the "That should hold" mentality is in order here.
I do not argue the choice of carbon steel in the bilge, nor do I argue that fiberglass would be a better alternative where corrosion is an obvious issue, but I wonder why the original designer chose to use steel when it would have been easier, and probably less costly to use fiberglass. The steel piece was most likely an outsource for the builder when he had an entire staff of workers skilled in composite layup.
I also have developed considerable caution about people who blithely state that it should be done "this way" with no data, empirical or otherwise to prove the point. I had a professor in university who lectured a course on empirical science who used to talk about the desire to prove a point with no data as " Proof by violent waving of the arms..."
Feetup
Old 05-13-2008
Great follow-up. I'm going to call up a local shipwright and pull him into the full discussion and have him explain the materials as well as the design consideration. I wish Bill Lapworth (SP?), father of the CAL boats was around to email...would be fun to have him chime in.
Thanks Feetup.
1974 Cal 2-29
Juneau, Alaska
Old 05-13-2008
chucklesR's Avatar
chucklesR chucklesR is offline
Gemini 105Mc Hull 987
chucklesR is a jewel in the roughchucklesR is a jewel in the roughchucklesR is a jewel in the rough
If it is broke, fix it better than it was, or suffer multiple failures.
Good post SD, unfortunately your positive rep points have to wait as I have to spread them around some.
Old 05-16-2008
Hartley18's Avatar
Hartley18 Hartley18 is offline
Blue Heeler
Hartley18 will become famous soon enough
I gave him some for you, Chuckles.
Cameron
Broker to potential buyer: "Too expensive? Buying a boat is an EMOTIONAL decision - not a financial one!!"
To get the most from Sailnet, follow the link in Craigtoo's signature...
Old 05-16-2008
Unfortunately, cost is often a consideration... and the customer's long term benefit is ignored in search of profit. I have seen that on many boats, including my own. But when you're repairing a failed structural piece of hardware, I see absolutely no reason to blindly repeat what the manufacturer did. Doing so is taking the easy way out... and often will not yield the optimal results.
Display Modes
vB code is On
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
