Blogs
Go Back   SailNet Community > General Interest Forums > Sailboat Design and Construction
User Name
Old 04-01-2008
Gillfowdy Gillfowdy is offline
Gillfowdy is on a distinguished road
Transom Cutout for Outboard...Problems?
Hello,
I have a 1976 Grampian 26 powered by a 15hp Honda 4 stroke outboard.
It's mounted to the transom at the factory location cutout.
My question is , does anyone have a problem with this design re following seas or any other problems? I know when I motor at hull speed, there is very little room between the water level and the cutout.
Phil
Old 04-01-2008
Faster Faster is offline
Just another sailor
Faster will become famous soon enoughFaster will become famous soon enough
That's a pretty big, heavy engine for a 26 foot boat and when you're pushing hard the boat will "squat" quite a bit, lowering your apparent freeboard accordingly.
I don't think it (the cut-out) would be a problem in following seas unless you were motoring hard downwind at the same time... presumably if it's that rough you'd do better sailing anyway.
A lighter motor will help, but of course you're unlikely to want to go that route.
I'd experiment with the throttle settings, and see exactly how much speed you actually lose as you back the throttle off a bit, as opposed to how much you reduce the "squat" at the same time. There's usually not much point in over-driving a displacement hull for the little speed gain you may get. You really just make bigger waves and use more fuel...
Boating in BC waters since the '60s, sailing since 1981.
Currently on our 5th boat, a 1984 Fast/Nicholson 345.
Old 04-01-2008
Hartley18's Avatar
Hartley18 Hartley18 is offline
Blue Heeler
Hartley18 will become famous soon enough
Ditto what Faster said. I'm not sure that 4-stroke outboards were in fashion in 1976, so you'll probably find it's a heavier motor than the designer had in mind. Make sure:
1. Your transom is strong enough to handle it. (Just check that you're not getting stress cracking..)
2. You get the trim right. (Try to offset the weight by moving heavy items forward in the boat..)
"The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective."
-Henry David Thoreau
Old 04-02-2008
Bermuda30's Avatar
Bermuda30 Bermuda30 is offline
On Blocks
Bermuda30 is on a distinguished road
Never had any problems with it, though have not been in following seas larger than 3'ish yet. I have an older 8hp Yamaha, sit close to the water, but not dangerously so. The cutout should have slots for you to place a piece of 1/2" ply in the cutout, provided you pull the motor if it really bothers you. Only done this once, don't think it was really necessary. Do upgrade your scuppers though, the little 1" transom dumps aren't exactly the fastest flowing in a swamping situation.
1971 Grampian 26
Old 04-02-2008
Plumper's Avatar
Plumper Plumper is offline
Sailor
Plumper is on a distinguished road
The problem is not from waves coming in the cockpit, it is if the waves wash right below into the boat. Given that the companionway opening on a G26 is so close to the level of the cockpit sole you should consider leaving the lower washboard in (and secured) when there is any chance of being pooped at all. There is nothing worse than a big gulp of saltwater down below!
There is a tide in the affairs of men,
Which, taken at the flood, leads on to fortune;
Omitted, all the voyage of their life
Is bound in shallows and in miseries.
Shakespeare, Julius Caesar IV, iii, 217
Old 04-02-2008
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
This is why I built a proper bridgedeck for my boat.
—Captain Malcolm Reynolds, Serenity (slightly edited)
If you're new to the Sailnet Forums... please read this POST.
Old 04-02-2008
Bermuda30's Avatar
On Blocks
Indeed. The Gramp companionway bottom is about 6" off the cockpit sole stock. I myself intend to build a full bridgedeck to cockpit seat height at a later date, before venturing further offshore. There's a lot of volume in that cockpit, and a bridgedeck is a good way to solve the companionway height issue and reduce the volume for waves to swamp.
1971 Grampian 26
Old 04-02-2008
Bermuda30-
If you want to see the install I did on my boat, let me know... I'll pm you a link.
Old 04-02-2008
Plumper's Avatar
Sailor
My Ranger 26 was a similar boat to the Grampian and it had a motorwell like a power boat. It basically consisted of a bulkhead in the after part of the cockpit ahead of the engine mount cutout so that an overtaking wave would just fill the motorwell. If you see a Ranger 26 check it out. That is another solution to the problem.
Old 04-02-2008
Thanks for the quick reply. I do plan to keep the 15 even though it's heavy. 103lbs!!! It runs great and is what I got with the boat. Keeping some items forward in the boat seems like a good idea for weight balance. I do have a piece of ply to fill the cutout but only use it during storage of the boat. I don't know where I'd put that huge thing if I removed it during a sail!
The scuppers are small but I've never even had any water in the cockpit yet I sail Lake Huron and intend to head north to the North Channel this summer so could run into some not so nice weather. May need larger ones I guess. I would like to see the bridge deck mod if you could forward the pics to thebus@sympatico.ca
Thanks
Phil
76 Grampian 26
Irish Mist
Display Modes
vB code is On
HTML code is Off
Prospective New/Recent Tartan Buyers Note camaraderie Buying a Boat 273 2 Weeks Ago 11:34 AM
C & C 121 Customer Response to Manufacturers Post camaraderie Tartan 0 09-10-2007 06:43 PM
Installing a transom Hargadoo Buying a Boat 10 08-29-2006 03:59 PM
RIBs with Fold Down Transom timl Gear & Maintenance 0 02-10-2003 07:55 AM
Resolving Some Classic Boat Problems Beth Leonard Miscellaneous 0 07-13-2001 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
