While repeated point stressing may well result in the damage to the fiberglas structure you cite I believe there is ample evidence of fiberglas' resiliency in both the automotive industry and the boat building industry. I've witnessed the type of disconcerting flexing being discussed and also seen it pop back with no evidence externally or internally on the boat of any significant damage.
There have been many replies similar to yours. I am not speaking of fishing poles or automobiles. The resin used in those applications differs compositionally from that favoured for boats. Boats are designed to be stiff.
That said - the damage does not occur so much to the resin. The thing that is irreparably damaged is the glass fibre in the roving, and unless you open it up and look at it with a microscope, you are not going to notice it. It is not likely to show to the naked eye until the damage has become quite severe.
There is "resiliency" in the fibreglass, and it can return to it's original contours, as that is the shape that is inherent hence requires the least amount of energy to maintain.
The fibres are not elastic however, and once bent or crushed, they are forever changed. It is possible that their structural integrity will allow them to avoid being bent or crushed in the case of light impact, however, in the case of prolonged loading - particularly if you hear that brittle crunching kind of sound when the boat hits the jackstands and one of the stands is too high - the damage is permanent.
