Main Halyard length - Page 2 - SailNet Community
post #11 of 14 Old 04-22-2008
artbyjody's Avatar
My rule of thumb for any line is 20% over what is required. That allows for splicing in a emergency (unlikely but chafing etc - plausible). The problem with having so much more than required is that its is more maintenance and tending to. On my C-27 the halyards were literally 15 feet longer than necessary. That made coiling and the amount of line that could tangled - more than what was necessary to deal with. My Barberis is no different, as I have some of the shroud tensioning lines that are 20 feet over what is needed, and ends up being just a pile of line that hangs there adding more weight to the boat and more to tend to.
Since I also believe in using downhauls as well - I am a bit more allergic to having more than necessary line as already - I have enough that will tangle and get in the way. Therefore I like to have 20% more and no more or less. If you carry spare line as I do you will never run out in a emergency situation as it is simple to extend what you have for say a MOB situation.
Just my 2 cents...think of the manageability and whether a line needs to be oversized - and if so how much do you want to deal with splayed all over the cockpit assuming you have it rigged for single handling.
-- Jody
S/V "
1983, Barberis Show 38! or
artbyjody is offline
post #12 of 14 Old 04-22-2008
merttan's Avatar
I'll tell you what I have, that maybe help...
1.25 lenght of the mast with steel cable with each end spliced to a shackle. Thus, I can connect or disconnect the sails easily and replace the rope part accoring to my needs... If I'd need to bring the rope part to the cockpit in future, I can just change the rope or if the rope wears out or damages along the way, I can, again, change the rope without dealing with the replacing the whole system...
" I refuse to engage in an intellectual battle with an unarmed man!"
Materialism: Buying the things we don't need, with money we don't have, to impress people who don't matter.
merttan is offline
post #13 of 14 Old 04-24-2008
Other than strength, is there a reason to use steel cable instead of rope? I have steel cable already installed without questioning...now is the opportunity.
jbibb is offline
post #14 of 14 Old 05-01-2008
Rope halyards stretch in a blow,cable halyards don't. I hate it when my halyards slap against my mast, so I leave enough length to tie both ends off to a lifeline stanchion base, and I avoid boxers.
rkfitz is offline
Retrieving Main Halyard from top of Mast? CapnSantiago Gear & Maintenance 58 05-22-2012 09:14 PM
How to Retrieve Lost Main Halyard JimRockfish General Discussion (sailing related) 49 08-13-2007 09:24 PM
main halyard Sailmale Gear & Maintenance 5 06-20-2002 09:25 PM
Rereaving the Main Halyard Dan Dickison Racing Articles 0 02-11-2002 07:00 PM
Jib and Main Halyard Trouble siem Gear & Maintenance 1 07-16-2001 10:08 AM
