Blogs
Go Back   SailNet Community > General Interest Forums > Sailboat Design and Construction
User Name
Old 04-14-2008
rdbeales rdbeales is offline
rdbeales is on a distinguished road
Pearson 33 with pressure dents from jack stands
1970 Pearson 33 Boat For Sale
I'm looking a this 1970 Pearson. Seems like its right up my alley. However, one of the jack stands has clearly pressed in the starboard bow. Its a big soft dent. No cracking of paint or gelcoat that seems to be related. Anyway, I was told that hulls will rebound from this kind of deformation once re-floated. Any truth to that? How serious is this kind of thing? I have no way of easily looking at the stringer locations and condition and such because of the fiberglass insert interior so I figured I'd ask here first.
Please give me reasons for your opinion, not just don't worry, or no way.
Thanks for your time.
Dave
Old 04-14-2008
Stillraining's Avatar
Stillraining Stillraining is online now
Stillraining has a spectacular aura aboutStillraining has a spectacular aura aboutStillraining has a spectacular aura about
Some one else will have to confirm...but sounds like a cored hull with rotten core in that spot...Solid hulls wont do that...
Old 04-14-2008
Supposedly this hull is solid. Anyone know Pearson construction in 1970?
Thanks Stillraining!
Old 04-14-2008
Plumper's Avatar
Plumper Plumper is offline
Sailor
Plumper is on a distinguished road
Is the weight of the boat on its keel or is the weight on the jack? The keel should be carrying the weight and the jack should be balancing the boat. Lighter built hulls that oil can when on jacks should have the jacks placed on areas that are supported inside with frames or bulkheads.
Properly designed and built boats should not oilcan on jacks. Particularly small boats.
I would be concerned and ask my surveyor. I would not like to see that portion of the hull flexing when beating into a nasty sea.
There is a tide in the affairs of men,
Which, taken at the flood, leads on to fortune;
Omitted, all the voyage of their life
Is bound in shallows and in miseries.
Shakespeare, Julius Caesar IV, iii, 217
Old 04-14-2008
So far I'm not hearing anything good, which is okay, I'd rather learn it the easy way than the hard way. The keel was resting on some blocks. You're right, it shouldn't be a great deal of weight, just balance. So the hull must be relatively weak to bend, right?
Anyone with construction details or other info please contribute. I'm definitely trying to eliminate/exonerate this boat before paying for a survey. I only want to pay for that if I can't find anything seriously wrong with the boat myself.
Old 04-14-2008
Then I would suspect fracture dammage to the laminate in that area...Like hitting a log or dock pretty hard..
My boat had a soft spot from a dock collision...I had it completely ground out and back to solid material and relaid up...If the hull is so thin as to oil can as plumper mentions and it is sitting on its keel...I would walk away..Its one thing to fix a damaged area...its another to have a week hull..
Old 04-14-2008
Thanks for you input you guys. I have a bad habit of being optimistic. Possibly a fatal flaw while shopping for a boat But I had to ask about such a possibly serious situation. And know I now. Thanks.
Still curious about Pearson being solid or cored. Any thoughts everyone?
Old 04-14-2008
capn_dave's Avatar
capn_dave capn_dave is offline
Seinor Member
capn_dave is on a distinguished road
Ahoy RDBeals
The 1970 Preasons are not cored and are pretty good boats. As for the stands bending the hull, it can happen. It usually is no big thing. I don't know how long the the boat has been sitting on the hard, but it can settle and there can be allot of weight on that stand. The glass will bend if there is no bulkhead where the stand is located.
If it really worries you Have them move the stand and see if the bend comes out. I'll bet it pop's right back out. It could take a couple of days though. I see it all the time in the yard here and we just loosen the stand a little. It usually happens when the boat had been in storage for awhile.
Fair Winds
Cap'n Dave
Old 04-14-2008
sailingfool's Avatar
sailingfool sailingfool is offline
I would agree that this age pearson would be a solid glass hull and should be quite sturdy. Unless there is fracturing of internal members, frame or funrniture, near where the jackstand is, I'd bet it just happens to be positioned on a long runl with no interior support. If no damage inside, I'd have the yard look at repositioning the stand(s) and I would bet the issue disappears. The P33 is a nice quality boat, give it a second lookover.
SF
CS 36T
Need a bottom scrub...
Old 04-14-2008
JimsCAL's Avatar
JimsCAL JimsCAL is offline
JimsCAL is on a distinguished road
From the ad pictures, the boat is in a cradle, not stands. Pearsons of that vintage are pretty solid boats. Probably just a pad tightened too much. Have it backed off.
Display Modes
vB code is On
Jack stands GBurton Gear & Maintenance 19 10-11-2007 07:08 PM
Breadmaker aboard CHRISTINE-R Provisioning 21 08-14-2006 11:43 PM
Pearson 36 vs C&C 37 dnr Buying a Boat 1 11-16-2002 04:07 PM
Finding Jack Stands Jerry Hammill Gear and Maintenance Articles 0 09-05-2002 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
