Blogs
Go Back   SailNet Community > General Interest Forums > Sailboat Design and Construction
User Name
Old 04-25-2008
boydgatlin's Avatar
boydgatlin boydgatlin is online now
boydgatlin is on a distinguished road
Question Bilge pump dump below water line
Why on earth would a sailboat designer/manufacturer put the thru-hulls for both the manual and automatic bilge pumps below the water line? Seems like asking for unnecessary risk. This is exactly what we have on our 42 ft CC Beneteau, made in France. In addition, the associated seacocks are accessible only by removing panels held in place by 4-6 screws. I can imagine the scramble to get to them should a hose or clamp fail. One is accessed through a lazerette, and the other is beneath the propane locker via the aft cabin. The only defense would seem to be keeping the hoses, seacocks, and clamps in pristine condition at all times, despite the inconvenient access.
Does anyone know if a significant number of other boats have underwater bilge thru-hulls? What could possibly be the rationale for the arrangement?
Old 04-25-2008
merttan's Avatar
merttan merttan is offline
merttan is on a distinguished road
That's exactly what they want the boat owners to do...
No actually, they may be trying to make hull look good all times... Like no water marks on the hull from a above waterline outlet...
They might figured that if the bilge pump doesn't allow siphoning water back in they should be ok...
As I said, if the bilge pump has a oneway outlet and a high loop, then a seacock on the throughhull, it should be fine... You said access was covered, that doesn't make any sense...
I've seen lots of through hulls, those might be bilge pump oulets, below water line...
" I refuse to engage in an intellectual battle with an unarmed man!"
Materialism: Buying the things we don't need, with money we don't have, to impress people who don't matter.
Old 04-25-2008
Stillraining's Avatar
Stillraining Stillraining is offline
Stillraining has a spectacular aura aboutStillraining has a spectacular aura aboutStillraining has a spectacular aura about
All my boats were above water line both power and sail so Im no help...I agree with both your concerns...My bilge pump lines are thin wall and not designed to keep water pressure out...I would have to take a guess that they at least put a vented loop and a check valve in that design?....But on a nice boat such as yours I would personally change both issues if it were me...
Old 04-27-2008
BenthosCritter BenthosCritter is offline
BenthosCritter is on a distinguished road
The head discharge is below the waterline so that one does not have to smell the effluent. Bypassing the holding tank should only be done where it is legal. If the bowl of the head is still above waterline when heeling, then siphoning is not a problem.
Benthos Critters United.
Display Modes
vB code is On
Potable Water tdw Provisioning 31 08-11-2007 07:30 AM
Where do your bilge pump hoses exit? 7tiger7 Gear & Maintenance 3 07-07-2007 08:40 AM
Help Needed with Bilge Pump (Again) gpd955 General Discussion (sailing related) 26 09-01-2006 12:09 PM
Pumps—An Overview SailNet Miscellaneous 0 12-31-2000 07:00 PM
Bilge Pumps SailNet Miscellaneous 0 12-31-2000 07:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
