04-27-2008
Super Moderator
There are few cases where blisters are only strictly cosmetic. For blisters to be 'only cosmetic'I can only think of two possible cases;
1. Where there was a failure to bond between the gelcoat and the laminate and the laminate needs to be something impermiable like vinylester resin. In that case the blister is strictly in the gelcoat and not an issue.
2. Where the blisters are only in the barrier coat or the bottom paint, and does not extend into the gelcoat and laminate.
The first case is not very common but may become more common as vinylester resin and infusion become more common. The second case is more common, but is pretty easy to detect by flipping open a couple blisters and you should see clean intact gelcat.
Anything else, the laminate is involved and blister repair will continue to be a part of your general maintenance regime. Over time blister problems usually become more extensive. So I think if it was me, and I really liked the boat, I would probably get a second surveryor to only look at the blister problem, and depending on what he says, if he thought it was minor but in the lamimate, I would probably follow your option three. If it was more widespread and deeper in the laminate, then I'd follow your option 2. Major peel type blister jobs are the only way to really make a permanent repair and peel and repairs are a pain in the butt with the boat out of commision for a long time.
