Blogs
Go Back   SailNet Community > General Interest Forums > Sailboat Design and Construction
User Name
  #11 (permalink)
Old 1 Week Ago
feetup feetup is offline
seeker
feetup is on a distinguished road
I have heard several people bemoaning the steel beam in their Cals and always wondered why the designer chose not to make a glass, or glass over ply hard point. It seems like a no brainer that the steel is going to deteriorate faster than any other part of the hull, and yet there are so many things that they got right in that design. The beam itself is not that robust, and taking Sailingdog's thoughts to practical conclusion I don't think it would be that hard to build a glass or glass/ply beam of adaquate or surplus strength and rigidity. Use my favourite engineering principle and overbuild if you're not sure of the dynamics.
It seems quite obvious that in the case of the OP where a replacement is difficult or impossible to obtain, and maybe not the best idea in the first place that a robust hand laid replacement would be the answer he is looking for.
Good one Sailingdog.
Feetup
  #12 (permalink)
Old 6 Days Ago
Sailormann's Avatar
Sailormann Sailormann is online now
Here .. Pull this
Sailormann is on a distinguished road
If it was my boat I would not replace it with a piece of metal. I would cut a shaping form and then buy carbon fibre and fibreglass tape. I would laminate these alternatively until I had a solid beam that was thick enough. It would not rot and it would be very easy to install if I had the foresight to lay in some cross strips to use as tabbing from a few different layers.
Failing that I would do as SD suggested. The last thing I would do would be to put metal in my bilge area.
GOod Luck
Display Modes
vB code is On
HTML code is Off
Main Bulkhead Material Suggestion jbibb Sailboat Design and Construction 2 3 Weeks Ago 03:29 PM
Eliminating my Bulkhead soulesailor Gear & Maintenance 12 01-18-2008 04:44 PM
Goodbye bed, hello storage GoodOldBoat Gear and Maintenance Articles 0 05-14-2007 08:20 AM
What can you tell from the numbers? brazilnut Buying a Boat 9 11-18-2004 01:44 AM
Radar Glossary Jim Sexton Miscellaneous 0 09-29-1999 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
