05-24-2008
It really depends on the size of the boat, but considering that you asking about passing under bridges, I am guessing this is considerably bigger than a sailing dinghy.
However, if you mean hinging the mast in the center of the spar, when you say "Hinging a mast in the center," you're either mad or a complete idiot. JMHO.
Generally, the loads on a mast are generally such that you don't want a weak point in the center of the spar. Also making such a hinged point would add quite a bit of weight aloft, if the point were to be strong enough to take the loads experienced by a spar.
Most setups that allow you to drop the mast on the water involve using a tabernacle setup or a hinge point at the mast step. Generally, a mast step-type hinge is limited to smaller boats, due to the size and weight of the spar.
My boat, which has a 35' 6" mast, has a mast lowering system, but the spar is lowered as a whole, using a series of A-frames instead. I can lower or raise the mast using a single control line. The process can be stopped at any point and reversed at any point if need be.
