05-30-2008
Adding a staysail will not make it a cutter as such. Such a rig is generally called a double headsail sloop or slutter.
The difference is that the cutter is designed to have both headsails flying at once, whereas the slutter would usually have just the one. However it is possible to have two but this depends on the overall design, and performance may suffer.
There is at least one other thread on this but there are some misconceptions so it might help if I try to explain my conception of what is happening.
What is required for boat balance is that for simplicity there be equal sail area fore and aft of the centre of lateral resistance the point of balance of a boat. This assumes both sails are trimmed correctly eg luffing the main effects the force aft.
Similarly one boat may have a large headsail and smaller main or vv.
In the former case the mast is set further back.
Simply adding an extra sail does not increase power because the windforce is a function of the mass and speed of the air diverted.
That means that the same mass of air goes through the foretriangle whether it passes over 1 sail or two.
However two factors come into it.
Forward drive is mainly produced in the luff area, rather than the flat area, so in theory two luff lengths should give greater forward drive. In other words the air diverted remains the same so the force is the same but the resultant forward component of the force differs.
The catch is (although this gets complicated) that the force comes from laminar flow.
The extent of this depends on having the right slot size.
If it is too narrow as you would have seen you backwind the main or the inner sail, which cuts out the drive in the part that produces the forward force.
On a sloop that slot size is designed in.
On a cutter a bowsprit is required to give the extra separation for a second slot.
On a slutter you don't have that capacity without moving the mast back chainplates and all.
The other issue is to use 2 foresails at once you need to maintain the slot along the whole luff length so the luffs are parallel.
To do this means that the staysail is lower on the mast which will usually require running backstays to strengthen the mast at that point.
The alternative is to use a solent rig or or an inner forestay which which is set back only a couple of feet and terminates at much the same point as the outer forestay and may be detachable to allow for easy tacking without the furling the genoa to stop it hooking up.
In this case only one headsail is used at a time except perhaps downwind.
This has an advantage of better sail set using a dedicated sail on the inner stay rather than partly furling a genoa, where in effect you furl the part with the draft built in, in stronger wind conditions.
However you still have to balance the sail plan against the reefed main.
So in answer to your specific question you seem to assume greater sail area forward, (if in fact it is greater rather than just distributed between two sails for ease of sail handling) may need to be balanced by greater sail area aft.
This might be done by using full battens to get a bigger roach, however first you have to establish form whatever configuration you set up if in fact you have greater force rather than less, and secondly what the sail balance was like previously and after the other changes. For instance you may have had weather helm and increased it.
On the other hand if you added a bowsprit you may have eliminated it.
So you see it is not as simple as interposing a staysail.
