Is this gash fixable? - Page 2 - SailNet Community
post #11 of 27 Old 07-07-2008
Owner, Green Bay Packers
As usual, Jeff brings up some good points. Given the level of restoration needed for this boat it would be unconscionable to not make a thorough examination of the entire hull and superstructure and reinforce those points that Jeff points out as well as any others showing evidence of stress. It will be much easier to do while you're in "fiberglas mode" than doing so later and you'll be naturally inclined to do a better more thorough job.
Wm. F. Buckley, Jr.
sailaway21 is offline
post #12 of 27 Old 07-07-2008
Sailaway's point is a good one... if you're going to be fiberglassing...you might as well do all of the reinforcing that you have to do all at once.
sailingdog is offline
post #13 of 27 Old 07-07-2008
SailAway
maccauley123's Avatar
I had a Venture 22 and really like the boat. While not an offshore boat by any means it is a good little boat and sails well. A lot of fun. I also found mine rotting in a yard and restored her. No hull work but had to replace the keel winch and all interior bulkheads needed replacing.
Get a copy of Don Casey's "This Old Boat". Packed with practical information on every aspect of your project. I refer to it often.
You will regret the things you did not do, more than the things you did.
Get out there!
Saco Bay, Maine
2001 Beneteau Oceanis 361
maccauley123 is offline
post #14 of 27 Old 07-07-2008
Just a thought on your fiberglass repair. Your boat was built using an ester resin so I would not go to the expense of an epoxy resin ( for a number of reasons). One would be that if the repair is thicker than the original hull and with a different material it will cause a rigid hard spot in the hull and new cracks will form around it causing more problems later. Polyester resin will be cheap and is easy to work with. There are countless books and videos out on how to fiberglass repair. Your best secret tool is to get a resin roller from the supplier. It will work out excess resin and make the repair a much higher quality. There is too much to list any more. In short it may not be pretty but it's under the water line.
funsailthekeys is offline
post #15 of 27 Old 07-07-2008
I wouldn't use a polyester or vinylester reson for a STRUCTURAL REPAIR. The secondary bonding (adhesive) characteristics of polyester and vinylester resins basically suck compared to epoxy resins.
This is especially true if the boat you're going to be repairing is older, since the older the boat, the longer the laminate has had to cure and the fewer styrene bonding sites will be available for the polyester/vinylester resins to bind to. Using a polyester/vinylester resin on this type of repair is a pretty good way to guarantee you're be fixing it again, since it won't bond strongly enough to create a lasting repair.
BTW, epoxy resins, depending on their formulation, aren't necessarily any harder than polyester/vinylester resins and most structural repairs are done with epoxy from what I've seen.
IMHO, your advice is pretty much off the mark and I think you should probably do a bit more research on Epoxy, Polyester and vinylester resins with regards to STRUCTURAL repairs.
post #16 of 27 Old 07-07-2008
Moderator
Jeff_H's Avatar
SD is right, epoxy has enormous advantages in terms of penetratring and peel strength properties relative to either polyester or vinylester. Epoxy is the only way to go when you are dealing with structural secondary bonds. Any increased stiffness from the repair should be mitagated by tappering the edge of the new laminate where it joins the existing work.
Jeff_H is offline
post #17 of 27 Old 07-07-2008
blueranger's Avatar
From the reading I did I was under the impression that for all practical purposes polyester resin has pretty much been eclipsed for boat building/repair purposes by epoxy due to it's superior strength and adhesion to differing materials. Poly is slightly cheaper but unless you're mass producing not enough to make a significant difference. Just my 2 cents.
Mike
blueranger is offline
post #18 of 27 Old 07-07-2008
Polyester resin is still used by a majority of the boat builders, primarily due to cost issues. There are also some complexities to using epoxy in boat-sized projects, like the need for a curing oven to ensure proper curing of all of the epoxy resin, that have also deterred some manufacturers from moving over to epoxies.
post #19 of 27 Old 07-07-2008
I would'nt worry about it......It'll buff right out...........
7Psych is offline
post #20 of 27 Old 07-08-2008
repair issues to polyester boats
Actually I have a bachelors degree in Marine Technologies and am certified in several areas of fiberglass repair including cobalt fiberglass repair. So with an engineering degree in this stuff as well as using it for 20 years I 'm pretty confident it would be a one time fix. Also the West system is for people that can't measure proportions correctly. For those of you that don't know, Cobalt fiber glassing is a 4 part mixture.
