08-29-2008
Provided the screws are properly bedded and gas-tight, the screws won't really compromise the box. If you're really worried about it... bolt the bracket to the locker, and then glass over the nuts on the interior. However, you would have to run a gas-tight hose from the exit vent of the locker to a through-hull to make the gas vent overboard, as is prudent and required by ABYC code.
Originally Posted by dodgydingo
I am leaning towards inserting a prebuilt locker into the lazarette next to it as I will be able to use a much larger tank and have all new fittings including a pressure gauge which the old locker doesnt have.
How would I secure the locker inside the lazarette.. If I screw a bracket along the bottom sides, wouldnt that compromise the box.. or would sealant solve that.
Also since I will be using a T junction to split to two lines (one for stove, and another for the furnace) how would I get a 3rd for a bbq in the future. Is it okay to run a second T junction right after the first.
