Blistering on Modern Boats - SailNet Community
post #1 of 7 Old 09-04-2008 Thread Starter
Solla Sollew
I have a 2006 Bavaria which, I believe, was fabricated with Vinyl Ester resin. From the Bavaria Website:
"A layer of isophtal acid resin in combination with a powder bound matt of glasfiber avoids the diffusion of water and obviates damage by osmosis."
I routinely keep the boat in the water year round (except for Spring short haul). An epoxy 'tie-coat' was applied to the yacht on delivery (mostly so the bottom paint would stick). Is osmotic blistering still an issue or did the chemists solve this problem years ago.
Thanks.
Eric
PS: Extra points if you're a chemist or engineer.
SollaSollewSails is offline
post #2 of 7 Old 09-04-2008
Vinylester resins reduce the possibility of osmosis, but AFAIK, they do not remove it altogether. Even an epoxy barrier coat, which is probably a bit more substantial than your tie coat won't necessarily prevent osmotic blistering.
sailingdog is offline
post #3 of 7 Old 09-04-2008
what does afaik mean>
SollaSollew is offline
post #4 of 7 Old 09-04-2008
TIKI TIME's Avatar
I believe it means As Far As I Know...
C&C 33 MKII
TIKI TIME is offline
post #5 of 7 Old 02-02-2012
SollaSollew, how do you like your Bavaria? (if you still have it)
seakingbubba is offline
post #6 of 7 Old 02-03-2012
denverd0n's Avatar
Don't expect an answer, seakingbubba. This thread is from 2008, and the OP has not posted since then.
denverd0n is online now
post #7 of 7 Old 02-06-2012
Cruising at a snail pace
I never have read of bistering being a problem on newer boats (like newer than 1985).
In walking the boat yard in the winter the only ones I see with any blistering issues are older boats. So whether they "fixed" it I don't know but it doesn't look to be an issue overall.
Don't blow air up my rear, be useful and blow it at the sails!
Don0190 is offline
Long versus short overhangs kwaltersmi Sailboat Design and Construction 105 2 Weeks Ago 11:11 AM
Buying first boat JandS Boat Review and Purchase Forum 13 12-09-2010 12:14 PM
Different take on the first boat drynoc Boat Review and Purchase Forum 34 04-09-2007 08:44 AM
Modern Production Boats Don Casey Buying a Boat Articles 0 12-13-1999 07:00 PM
