Go Back   SailNet Community > General Interest Forums > Boat Review and Purchase Forum > Sailboat Design and Construction
Old 09-07-2008
mikeysoutheast is on a distinguished road
Selftracking Jib
Is anybody know how does selftracking staysail work with headsail?
Old 09-07-2008
johnshasteen's Avatar
johnshasteen is on a distinguished road
Before Paloma, I had a full keel cutter with a self-tending staysail. When tacking, you do exactly what you would do if the you had to tack both sails. You let out quite a bit of halyard on your headsail so it's whipping about, tack, then pull the hedsail through the slot between the headstay and the staysail stay.
s/v Paloma, Bristol 29.9, #141
Slipped in Bahia Marina, easy access to Corpus Christi Bay and the Gulf of Mexico.
Old 09-07-2008
I believe he means that you let out the sheets, not the halyards... You generally don't muck with halyards much when sailing a boat, much less when tacking one.
Old 09-08-2008
Ilenart's Avatar
Ilenart is on a distinguished road
Mikey,
I would'nt normally use my staysail in conjunction with my headsail when closehauled as the two normally interfere with each other. therefore tacking with them both is not really an issue.
I found this article pretty useful when I first started using my staysail.
http://www.quantumsails.no/upload/So...e_and_trim.pdf
Ilenart
Sailing Basics Steve Colgate Seamanship Articles 0 03-09-2003 07:00 PM
Sailing Basics Steve Colgate Her Sailnet Articles 0 03-09-2003 07:00 PM
Sail Trim Steve Colgate Learning to Sail Articles 0 05-10-2000 08:00 PM
Sail Trim Steve Colgate Seamanship Articles 0 05-10-2000 08:00 PM
Sail Trim Steve Colgate Gear and Maintenance Articles 0 05-10-2000 08:00 PM
