09-10-2008
I would be cautious about adding ballast, especially at the bottom of the board. Increasing the ballast on the board will increase the forces the board is subjected to, the forces on the lifting rig and the forces on the shrouds. If not done properly, you're much more likely to snap a shroud and lose the mast.
Have you done as much as possible to flatten/de-power the sails?? Are the sails in good shape or are they all blown out.
I agree SD, and my caution would be in direct proportion to how much I cared about the boat.
If you push the envelope far enough something will break.
If you don't mind getting wet and fixing what you break, Whose to say whether it's worth it or not.
I am often asked about up sizing rigging. My usual response is that it was designed by someone who actually went to school to learn how to design things, and it has performed for however many years without failing and that I don't feel qualified to second guess the designer.
I tell them that there is always a "weakest link" and unless they are willing to follow through and beef up the entire system, then they are not really gaining much.
But the customer is always right. And if it helps them sleep better at night, I'll take their money.
Ron Paul 2012
"wikijar"
