09-18-2008
If you have three wenches aboard, you must not be married.  Winches on the other hand might be useful equipment.
Where are the jib sheet fairleads?? If they are inside the shrouds, the sheets should run inside the shrouds. This is usually the case with jibs. With Genoas, the tracks are usually outside the shrouds and the sheets should be lead outboard of the shrouds as well.
Be aware, that some Cals, especially if they were rigged for single-handed racing, may have the coaming winches setup for cross sheeting, rather than regular sheeting and will tend to override if you run the sheets from the turning block to the winch on the same side. Cross sheeting allows the single-handed sailor to sit on the high side and control the genny sheets from there.
