Go Back   SailNet Community > General Interest Forums > Boat Review and Purchase Forum > Sailboat Design and Construction
Old 09-19-2008
bdkjones is on a distinguished road
C22 Front Hatch Replacement?
Hi all,
I'm about to buy a 1986 Catalina 22. Its front hatch (the one on the cabin top up by the bow) is made of fiberglass instead of lexan. I'd really, really prefer the lexan (see-through) front hatch.
Has anyone ever retrofitted an older C22 with the lexan front hatch? Is it possible to simply drop in a replacement or is the mold on the cabin top different for each hatch?
Thanks in advance.
-Bryan
Old 09-19-2008
djodenda's Avatar
djodenda will become famous soon enough djodenda will become famous soon enough
Congratulations in advance on your purchase of your C22!
As you have probably noticed, the 1986 and later models have significant improvements over the older ones (I had a 1988)
You can get a replacement hatch for your boat, along with almost everything else from
Catalina Direct: Welcome to Catalina Direct Online
They also have a message board, and the people there are very knowledgeable about your boat.
Good luck!
David
David
1987 CS 36 Merlin "Kyrie"
Old 09-20-2008
Found my Answer
Thanks David,
I'm well aware the hatch can be replaced. What I was looking for was a way to retrofit the newer, Lexan hatch into the older, fiberglass hatch opening.
Turns out, there is a solution (for those searching the forum in the future): Cruising Concepts/Catalina Retrofit Hatch It looks pretty sharp to me! Certainly beats the old fiberglass hatch.
-Bryan
Old 09-20-2008
djodenda's Avatar
Bryan:
Glad to hear it. Let us know how it works out, and, please, post pictures of your new boat.
I do miss mine...
David
David
Companionway Hatch Replacement danohayes Gear & Maintenance 9 10-23-2008 09:46 AM
Hatch replacement glyphus Quickstep 1 08-07-2008 01:19 PM
Engine Access Hatch, Fuel Pump Replacement Advice ahalfon Gear & Maintenance 2 07-08-2007 03:25 PM
Lexan Replacement Hatch for C30 latitude9.5 Gear & Maintenance 1 07-04-2006 12:14 PM
Resolving Hatch and Portlight Problems Tom Wood Gear and Maintenance Articles 0 03-17-2003 07:00 PM
