09-29-2008
Saildork-
Does your boomvang look like this:
or more like this:
If it is more like the former, rather than the latter, it will work to pull down the boom relatively well at all points of sail, but it will need much more leverage than if the bail were further out on the boom.
You probably want to move the bail out a bit further, since the angle between the boom and the boom vang is only 38.3 degrees or so... and you really want it closer to 45 degrees, if not a bit more. That will also give the boom vang a bit more leverage.
