Go Back   SailNet Community > General Interest Forums > Boat Review and Purchase Forum > Sailboat Design and Construction
  #11
Old 12-06-2008
mgmhead's Avatar
Somewhat Senior Member
mgmhead is on a distinguished road
I'm glad to say that my Sabre 34 MkI has a drain plug in the bilge and it is a relief knowing when stored on the hard with the batteries disconnected there is no fear of damage from standing water.
Also glad to say my cockpit DOES NOT drain into the bilge-ever!
s/v Rhythm
Catalina 387 #29
Rock Hall, MD
  #12
Old 10-24-2012
john
johno3 is on a distinguished road
Re: Removable bung in keel?
hi i own a orkney longliner fishing boat all orkney boats are fitted with keel bungs
  #13
Old 11-27-2012
downeast450's Avatar
Tundra Down
downeast450 is on a distinguished road
Originally Posted by mikehoyt View Post
Many boats at our marina have garbord drains.
Our boats are hauled during the winter and the marina is not patrolled regularly. Typically snow can fill the cockpit and than rain/freezing rain can put a hard layer over this snow and also cover cockpit drains. A mid winter rain storm will then fill cockpit to level of hatchboard and flow into boat.
This does not happen often but there are many ways in which water can find its way into an unattended boat over winter and easily rise to or over floorboard level. One boat in our marina had replaced the cabin sole only to have this happen over the following winter. After that a lot of boats installed garbord drains.
Another option is to remove the speed transducer to leave this as a drain. It is much higher than the bilge though and the possibility of water filling the bilge and freezing would still exist - though below the floorboard level.
Garbord drains are not at all difficult to install and unless you have a cored hull I do not see this as a major problem. I do however see water sitting in a boat on the hard as a major problem.
Mike
J27 #150
I installed one and am glad to have it here in Maine.
It isn't obvious in this picture but I added 1/2" of biaxial S-glass with vinylester resin to the inside of the keel stub to prepare for the plug's installation.
Down
  #14
Old 12-07-2012
lillia28's Avatar
Location: Central New Jersey, sailing on the Navesink River and Sandy Hook Bay mostly.
lillia28 is on a distinguished road
Do it! It provides great peace of mind. I got myself in a tizzy about what type of plug to use, plastic or bronze and decided to epoxy the hole each spring. Five minutes to drill in the fall, 10 minutes to fill in the spring, no worries, no leaks, no lost plugs. Piece of cake.
Lou
You may post attachments
You may edit your posts
My First Boat...Boat Term Question... Kacper General Discussion (sailing related) 38 09-23-2008 06:52 PM
Wing, fin, or bulb...what are the trade offs? langousta Gear & Maintenance 17 09-17-2008 04:54 PM
reducing keel/adding fin? abacosol Gear & Maintenance 9 07-01-2007 09:32 PM
Keel Bolt Repairs Don Casey Gear and Maintenance Articles 0 11-10-2003 07:00 PM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 08:00 PM
SEO by vBSEO 3.6.1
