10-05-2008
If you mean this boat:
I doubt it is a drascombe lugger, as the lugger was usually a ketch rig. It is hard to identify a boat without a decent profile image, so we can at least see the sheer line of the boat... A photo or painting of this image generally doesn't give much to go on.
Also, the Drascombe Lugger, even in fiberglass, will look like a lapstrake build, and this boat seems to have a smooth hull. Here is a photo of a Drascombe with only one mast up.
