Blogs
Go Back   SailNet Community > General Interest Forums > Boat Review and Purchase Forum > Sailboat Design and Construction
User Name
  #11 (permalink)
Old 10-08-2008
Giulietta Giulietta is offline
Giulietta is just really niceGiulietta is just really niceGiulietta is just really niceGiulietta is just really niceGiulietta is just really nice
Thumbs..
The topping lift should be eased once you hoist the main. for one main reason, because it prevents the booom to descend, it creates excessive twist in the main, spilling the wind above..release the TL once you hoist the main, ok??
Now, for that little boat I don 't see the added value in doing it..but if you sail in low to moderate winds, yes..by all means get a little roach..makes the boat look better..now..if said roach is going to cost more than $150.00 forget about it.
Does it have a boom vang? traveler?.with roach you will need a few more tools, ok?
  #12 (permalink)
Old 10-08-2008
AllThumbs's Avatar
AllThumbs AllThumbs is offline
midlife crisis member
AllThumbs is on a distinguished road
It has a traveler. I will have to check on boom vang but this can be added pretty easily as well AFAIK.
Alex, thanks for the excelent videos. You are my hero. All this time I thought the only mainsail control was the main sheet. (I sailed for the first time in July). I thought the outhaul just compensated for sail stretch as it aged. I thought the boom vang just keeps the boom from falling out of it's slot in the mast. I had no idea what a traveler might be for.
Thanks again. Eric
Back in the day, people were opposed to the idea that the world might not be flat.
  #13 (permalink)
Old 10-08-2008
Thanks again. Eric
Nahhh..I am my kid's Hero...not yours....(and even that, only until he finds I am a loser )....
Hey, please, man, don't need to thank, really..I do this to keep me busy while away from home..when i am home you rarely see me here..and just making you happy makes my day..I'll drive to my hotel happier tonight..and my walk around the Rock Springs, WY walmart will be the counterclockwise tonight!!!
Remember to release the toping lift next time, ok??
Sponsored Ad
  #14 (permalink)
Old 10-08-2008
uspirate's Avatar
uspirate uspirate is offline
Trim for Sail
uspirate has a spectacular aura aboutuspirate has a spectacular aura aboutuspirate has a spectacular aura about
For unwanted Roach...Home Depot sells anti-roach in a one gallon jug for $4.99.
should cure your problem
To get the most from Sailnet, read the link in SD's signature
BJ & Nimfa
S/V Flocerfida
  #15 (permalink)
Old 10-08-2008
knothead's Avatar
knothead knothead is offline
knothead has a spectacular aura aboutknothead has a spectacular aura about
Alex,
Maybe you should skip the Wall Mart tonight and go bowl a few frames.
You could probably use the upper body exercise.
"wikijar"
  #16 (permalink)
Old 10-08-2008
AllThumbs's Avatar
I remember when I was my son's hero. Now I have never been so stupid (he is 18)
Will do. (next summer)
  #17 (permalink)
Old 10-08-2008
tommays's Avatar
tommays tommays is offline
tommays is on a distinguished road
The J24s in our area only USE class approved sails to get there 174 PHRF and get the same rating if they do a JAM race
PHRF # we have two J105s one is and 81 and the other a 105
The boats i raced on this year with the roach problem are a Tartan 10,C&C 35 Mark I and a Tartan 372
All there race mains hit the backstay buy and easy 5"
Now is its faster BUT it is just a PITA for the crew to deal with
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
  #18 (permalink)
Old 10-08-2008
bobmcgov's Avatar
bobmcgov bobmcgov is offline
baDumbumbum
bobmcgov will become famous soon enough
If by roach you mean a convex leach, that's easy to accomplish but the performance gains are minimal. Doesn't add much at the head, doesn't add much forward thrust. Does smoth out exiting air flow. You will need longer, better battens to hold the fabric out.
The greatest gains in roach are made at the sail top -- going from a pointy head to a squared-off or PowerHead. That's where the wind is strongest and where your present sail is least effective. Two full-length battens would do ya. But unless you crane out your backstays, you may catch. (Our Bucc18 uses a powerhead. It's nice.)
If you live in a light wind area, you might profit better by ordering a main with deeper draft and/or full-length battens. As I mentioned before, the trouble on that cute keeler is gonna be controlling the slot. I'd focus on getting your main and headsail sheeting and twisting just so. That'll increase drive more than a couple sqft of fabric on the trailing edge.
Buccaneer18, Grainnia
SJ21, Diarmuid
  #19 (permalink)
Old 10-08-2008
max-on's Avatar
max-on max-on is offline
1997 Dehler 33
max-on will become famous soon enough
Ahh ok Thanks, crew accidents...
I was seeing something diffrent, like the boat broaching and stuff, you know...heeling etc.
I couldn't see that, because the main allways passes, even if stuck momentarily..
thank you.
Alex
Alex, that would be a 'roach broach'.
  #20 (permalink)
Old 10-09-2008
bestfriend's Avatar
bestfriend bestfriend is offline
Hitchin' a ride
bestfriend is a jewel in the roughbestfriend is a jewel in the roughbestfriend is a jewel in the rough
Once again, I have to come and bail all you guys out from your lame advice. Thumbs, my friend, this is what will happen to you if you add roach. Don't do it. It will ruin your life.
Great men always have too much sail up. - Christopher Buckley
Vaya con Dios
vB code is On
mainsail roach, battens, weather helm, and mast placement stipakb Sailboat Design and Construction 10 09-08-2008 07:30 PM
Adding a staysail to my 473 (2002, hull 78) craigp Beneteau 1 09-29-2007 03:17 AM
Adding halyards? wildcard Gear & Maintenance 19 06-04-2007 07:07 PM
Adding Air Cond. to Catalina 42 SteveInMD Gear & Maintenance 1 05-17-2007 09:29 PM
ADVICE NEEDED: Adding weight to keel FOLKBOAT yohosail General Discussion (sailing related) 5 10-22-2006 09:08 PM
Page generated in 1.5428 seconds (88.77% PHP - 11.23% MySQL) with 16 queries
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
