-   Sailboat Design and Construction (http://www.sailnet.com/forums/sailboat-design-construction/)
-   -   adding roach (http://www.sailnet.com/forums/sailboat-design-construction/47841-adding-roach.html)
AllThumbs 10-08-2008 05:00 PM
adding roach
If I am buying a new mainsail for a boat that originally had a mainsail with no roach, is it a good idea to buy a sail with some roach to try to improve performance?
This could make weatherhelm an issue (let's assume the boat is well balanced to begin with, just a little slow). Would the roach make a noticeable difference in weatherhelm? Would it make a noticeable difference in performance?
Why would a designer design a mainsail with no roach? Isn't it almost free performance?
Eric
tommays 10-08-2008 05:15 PM
Every PHRF boat that i have been on this year has a RACE main with MAX roach
The roach allways hits the backstay making it a PITA to tack in lighter air and even in heavy air the main takes a beating on every tack to get that last bit of performance
So i question the wisdom of allowing a roach that hits the backstay as i have seen a few accidents when it gets hung up
CharlieCobra 10-08-2008 05:43 PM
I could see it if the original sail had a hollow roach but not if it gets into the backstay.
AllThumbs 10-08-2008 05:55 PM
Yeah, I had not thought of the back stay, or the boom topping lift for that matter.
Giulietta 10-08-2008 05:59 PM
Tom, I am curious with those..can you explain how that happened and where?
I'm from the "land of big roaches" and never saw an accident caused by a roach stuck in a backstay...please help
Thanks
Giulietta 10-08-2008 06:02 PM
AT..is it for the boat in your avatar??
Why do you want to add? you sail light winds? If you do, it's ok, but the advantage speed wise is little. honestely..but if you want it..doesn't hurt that much...
tommays 10-08-2008 06:36 PM
I question it on PHRF boats because once one guy has it everybody thinks they need it
Are fall series was on Sat and we had 3 races with say 30 tacks and jibes each so that was 90 times the main had to be pushed
I have seen two things happen
1. A crew member thinks the main is sheeted in but it is hung on backstay as carefull as they should be about keeping there head clear of the boom :eek: they were not and when another crew poped it through without warning :(
This resulted in a trip to the ER with a fairly serious head injury
2. The crew trying to force it through during a tack or jib loses there footing when it clears and they have nothing left to balance on
While nobody got hurt doing this i have seen many stumble and hit the deck
Giulietta 10-08-2008 06:57 PM
Ahh ok Thanks, crew accidents...
I was seeing something diffrent, like the boat broaching and stuff, you know...heeling etc.
I couldn't see that, because the main allways passes, even if stuck momentarily..
thank you.
Alex
T34C 10-08-2008 07:09 PM
This is only going to be true if you are talking about a group of OD boats that are racing as a PHRF fleet (which your signature suggests) AND no one is actively managing the PHRF handicaps to adjust for changes in sail size.
Is this even a racing boat in question??
AllThumbs 10-08-2008 07:34 PM
1 Attachment(s)
That is my boat in the avatar but not the boat I am talking about here. I am looking at an older 20 foot boat with a tiny mainsail and no raoch at all. The boat (if I buy it) is due for a main sail soon so while I am getting quotes I need to know if I should be looking at a sail with roach or without. The boat is known to be a little pokey so I figured I would ask. Every little bit helps.
And no, I don't race.
My current boat has a roach on the sail and it does get stuck on the boom topping lift on a close hauled tack but only in really light air, and still the boom always swings all the way by no matter what, so it's not a safety issue. Sail wear could be an issue I suppose.
