Blogs
Go Back   SailNet Community > General Interest Forums > Boat Review and Purchase Forum > Sailboat Design and Construction
User Name
Old 10-11-2008
AllThumbs's Avatar
AllThumbs AllThumbs is offline
midlife crisis member
AllThumbs is on a distinguished road
what up with the plywood?
I looked at a boat today with plywood partitions under the sole of the cabin and under the cockpit. These partitions (bulkheads?) were tabbed in but not covered in fiberglass. The area inder the cockpit is basically a bilge, so this plywood is wet all the time, causing the tabbing to delaminate. The plywood is wet but not rotten. Is this typical construction? This is the second boat of this make/model (1973 DS 20) that is built this way.
Eric
Back in the day, people were opposed to the idea that the world might not be flat.
Old 10-11-2008
tommays's Avatar
tommays tommays is offline
tommays is on a distinguished road
It is more common than people would like to believe BUT look how long it lasted
It is a massive problem on power boats even some of the better ones
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 10-11-2008
hellosailor's Avatar
hellosailor hellosailor is offline
hellosailor will become famous soon enoughhellosailor will become famous soon enough
Probably built cheap as day sailors, designed to be hauled up and stored in racks overnight and cheap enough for camp classes.
Sponsored Ad
Old 10-11-2008
AllThumbs's Avatar
To fix, let it dry out for a couple months, cut the tabbing and retab? Then coat the plywood with epoxy?
Eric
Old 10-11-2008
bubb2 bubb2 is offline
bubb2 has a spectacular aura aboutbubb2 has a spectacular aura aboutbubb2 has a spectacular aura about
a few words, the first coat Penetrating Epoxy, than build it up with regular epoxy
Old 10-11-2008
Stillraining's Avatar
Stillraining Stillraining is offline
Stillraining has a spectacular aura aboutStillraining has a spectacular aura aboutStillraining has a spectacular aura about
Boy...wet all the time?..Plywood just does not belong in this environment no matter what you do to it...sorry but sounds like a major design flaw to me..
Bay-liner boats has a horrible reputation just for this reason. I have owned 3 of them and all suffer from ply delamination and rot.
Old 10-11-2008
merc2dogs merc2dogs is offline
merc2dogs is on a distinguished road
agreed power boats are worse
first power boat I owned had the 'bilge' under the sole with a small well for draining aft. when I repowered the old enging slipped off the hoist and came crashing down onto the sole and messed up the ply. First plan was to just repair the damage by inserting a section large enough to catch the stringers, but as soon as I started cutting I found mold and crap, found that everything in there was plywood, and nothing was sealed in any way, roughly half the stringers were tabbed in, the rest were screwed to those,or the 'backbone' and the sole was just screwed to the stringers and caulked at the perimeter. Everything was soft enough that you could delaminate it with your fingernails.
Boat at the time was about 6 years old.
I ended up spnding a month on that boat making everything from the sole down out of marine ply, and encapsulating it and tabbing everything together on the subassembly. Totally changed the behavior of the boat, and reduced maintenance a bit because a lot of things that used to work loose and get wobbly stayed solid, seats, engine cover and so on, figure the 'loose' floor system allowed everything to shift and wobble, when I redid it it acted as a single unit.
My Ariel has a couple 'open' pywood panels under the cockpit, and an unsealed area above the bilge, but I'm willing to leave it sit, as at 43 the plywood still looks as good as new.
Ken.
Old 10-11-2008
Perithead's Avatar
Perithead Perithead is offline
Watkins 29
Perithead is on a distinguished road
Yeah I agree with most everyone else, figure out some way to seal it and go sailing!
Old 10-11-2008
SVDistantStar's Avatar
SVDistantStar SVDistantStar is offline
'72 Pearson 36
SVDistantStar is on a distinguished road
Send a message via AIM to SVDistantStar
Do something to fix it.
1972 Pearson 36 S.V. Distant Star
vB code is On
Building a small plywood work boat SVDistantStar Gear & Maintenance 11 10-06-2008 09:07 PM
What's the best way to epoxy in plywood? duffer1960 Gear & Maintenance 8 05-29-2006 07:34 PM
Marine plywood VS. pressure treated (wolmanized) plywood duffer1960 Gear & Maintenance 8 03-03-2006 01:12 AM
Marine Grade Plywood? Vastbinder General Discussion (sailing related) 42 07-13-2005 09:37 AM
Plywood replacement Gene4er Gear & Maintenance 0 10-29-2002 06:41 AM
Page generated in 0.7023 seconds (65.89% PHP - 34.11% MySQL) with 15 queries
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
