10-12-2008
I think I may have the almost perfect boat for that.
1. Headliner just pops off in sections so no worries there for bolt access.
2. Every valve, pump, etc is within easy access (aft bunks are on wood slabs - lift up cushion and wood flats in sections, repeated through out the boat.)
3. Engine Access is 270 degrees .
4. Wiring is relatively easy to access.
5. Bilge - just lift up floorboards.
6. My interior is mainly screw in, but not too much is located "hidden" that requires disassembly (less the toe rail bolts).
7. All tanks are easily removable without moving anything major.
I think you need to look for a Barberis
-- Jody
S/V " To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. " - 1983, Barberis Show 38! or To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
