Go Back   SailNet Community > General Interest Forums > Boat Review and Purchase Forum > Sailboat Design and Construction
Old 10-28-2008
hns1934 is on a distinguished road
What is correct relative position of mast and boom
My questlion is should the boom be perpindicular to the mast when fitted properly with the main sail. On my boat, the sail is such that the boom drops below the horizontal by a noticeable amount when the sail is full up.
Old 10-28-2008
artbyjody's Avatar
artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice
Send a message via AIM to artbyjody Send a message via Yahoo to artbyjody
You should have a line called the topping lift, attached to the end of the boom. You use this to raise / lower the end of the boom and that will allow you to control the depth of the boom in conjunction with the vang and main sheet lines...
-- Jody
S/V "
1983, Barberis Show 38! or
Old 10-28-2008
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
Yes - it should.
Topping lift will get it back up there, but it sounds like your mainsail might have stretched a bit..
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
Old 10-28-2008
bubb2 has a spectacular aura about bubb2 has a spectacular aura about bubb2 has a spectacular aura about
It is the dreaded boom droop, it happens to all the older girls. I mean boats!!!!!
Old 10-28-2008
Actually, it depends on the boat... some boats have mast rake, and the rake needs to be accounted for when cutting the sails. Some have forward rake, which is a bit rare, but those sails might not leave the boom at a right angle to the mast... However, IMHO, most of the time, the boom is horizontal...
Old 10-28-2008
Delirious's Avatar
Pearson 31-2
Delirious is on a distinguished road
Boom parallel to the water is normal, even with an aft-raked mast. Is your mast perpendicular to the water? Sometimes the leech gets "tired" and the boom droops. Othertimes someone gets a grand idea and figures it is a way to gain a fraction of a square foot for an advantage in one design. I kid you not - there's even a name for it and I remember a protest filed by one Flying Scot racer against another that it was done deliberately.
I don't miss racing much.
There are also a couple one-designs that have two outhaul grommets to allow this as a mini-reef.
Charlie P.
To travel hopefully is a better thing than to arrive - R.L. Stevenson
I suspect that, if you should go to the end of the world, you would find somebody there going farther . . . - H.D. Thoreau
Old 10-28-2008
T34C's Avatar
Thanks Courtney.
T34C has a spectacular aura about T34C has a spectacular aura about T34C has a spectacular aura about
Some booms are designed with a gooseneck that fits into the slot on the mast and can be adjusted up and down. Sometimes these are adjusted and then locked into place and sometimes it is adjusted with a down haul at the gooseneck of the boom. Make sure the boom is in the correct position.
Maeven
Tartan 34C Yawl #282
Anything-sailing.com
Moderator
Old 10-28-2008
artbyjody's Avatar
Dog is right on his points - however about mast rake - some additional info for those reading and you sail not just a cruiser. Unless you have a race oriented boat (which doesn't seem to me you have) - Raking of the mast is more to effect to the genoa / jib and not necessarily the main.
They go hand in hand though...So, even in the race mode of things - there is a balance, and a bigger picture to be had. You can control the main and rake with the backstay. The rake of the mast controls the depth of the main but also the jib and genny. More rake means the the boom will go down to a certain degree but is designed to spill wind in higher winds. Less rake means the main, if the topping lift is adjusted correctly - will mean a tighter main for light winds.
However, rake effects the genny / jib. The main topping lift doesn't effect anything but the main.
When racing or wanting more out of the boat - when raking is desired you should adjust the foot of the genny / jib to give it the proper shape (something not typically done by those that do not play with their sails).
If you have dacron the average I think is 8% a year stretch. A decent sailloft can recut the main and make it more usable... but I think the problem you are describing is that the boom and topping lift. I know on my Baberis - the topping lift was an afterthought and just cleated off at the mast when I bought her.
-- Jody
S/V "
Old 10-28-2008
Jody-
My point is that:
If the boat has the mast rake set wrong, the boom may not be parallel to the water or at right angles to the mast.
If the sail has stretched out, the boom may not be parallel to the water or perpendicular to the mast.
If the sail was cut wrong, the boom may not be parallel to the water or perpendicular to the mast.
And that on some boats, the boom and mast aren't going to be perpendicular if the sail is cut properly and the mast is raked properly.
Old 10-28-2008
Here .. Pull this
Sailormann will become famous soon enough
You usually want to aim to have the mast pointing upwards and the boom pointing backwards.
You're welcome
Adjusting Your Rig Giulietta Gear & Maintenance 87 09-02-2011 10:32 PM
Boom Furling Revolution Tom Wood Cruising Articles 0 07-12-2002 08:00 PM
