as you can see in this photo the "skylight is there all ready.
I've been drawing, and the areas that stump me are the points that secure the slider to the runners. I'm thinking of routering a upsided down T into the rail (attached to the boat) and then using a flat stock piece of metal attatched to the slider hatch to keep it in place.
Then I have the problem of how does one keep water from coming in from the area where the slider goes into the seahood? I can make that a close fit, maybe adding a rubber seal?
FYI, the boat is a Westerly Pageant, a very dry cockpit. I can head out in 5 foot seas and stay dry. I've yet to get any water inside the boat. But even still I want hatch boards, this is a must.
Any points or tips would be great. I'm working on posting all my boat projects and would love to share the finished project here.
EDIT:
Here is a rough outline. I think if I used a wide piece of wood to fill the area between the slider and seahood, and make the slider a little long, so there is an overlap, that should help keep water out. putting a bit of an angle on might be a good idea too.
I would make a face to the slider as well that when closed matches up with the face frame for the barn doors, yet overhangs the doors a hair, and the hatch boards completely.
Allthough the drawing shows the runners ending near the seahood, they would really extend to the end.
I'm going to make a mock up to test the design. But I'd love to hear any flaws anyone might see.
