11-10-2008
David—
GC does make a very valid point. This was a serious problem in the solar thread previously....The battery bank capacity is measured in AMP-HOURS. The power required to move the boat should be measured in WATTS, or Amp * Voltage... and I am guessing that your figures of 30-50 amps to move the boat assumes 12 VDC... because if you need 30-50 Amps at 48 VDC, you're in a lot of trouble.
Originally Posted by gc1111
Davidpm,
Pardon the ranting from an old fogy physicist, but you are going to have continuing problems with electrical design if you do not understand the difference between amps and amp-hours. Not only understand the difference but consistently use the correct terms.
This lack of understanding and careless confusion of the terms seems to be widespread in sailing circles and has led to mistakes. It is akin to confusing the difference between speed and distance, which only rarely occurs because people have a more physical understanding of the terms.
