Should You REALLY Build Your Next Boat? - SailNet Community
Blogs
Go Back   SailNet Community > General Interest Forums > Boat Review and Purchase Forum > Sailboat Design and Construction
Old 01-20-2009
CaptainFredGreenfield's Avatar
Dodging Coconuts
CaptainFredGreenfield is on a distinguished road
Question Should You REALLY Build Your Next Boat?
There was a time, in the 1950s through the 1970’s, when backyard boat building was a worldwide craze. The thought of being able to build a boat from some crude drawings a stack of exterior plywood, some bronze/or stainless screws. A sack or two of galvanized nails, some fiberglass cloth and resin to add strength and keep the water out, coupled with a dream of sailing off to tropical isles for a few thousand dollars ( because after all, the wind is free) was enough to cause even some sensible people to convert their barn or shed into a berthing area for the perfect nautical escape module.
This cult of dreamers was made up of a large number of visionaries, societal drop outs, and even some hard working engineers and semi normal “Joe Lunch bucket” types who were near retirement or feared that they would soon be downsized out of their job. They fed off each others dreams, they followed the nautical pied pipers of the time. I know about these things, because I was swept up in that wave. I even invented and developed products to help these people make their (our) one off dreams.
My First Real Self Built Boat
In the early 60s my first “live aboard” sailboat was a 24 foot trimaran made of 3/8″ exterior ply which was glassed over. I built the whole thing and launched it in 90 days. It was a leading edge design and had minimal accommodations. A port-a-potty, no sink, a 5 horse outboard motor for power, a minimum sized mast and 3 sails, a main, genoa (forward sail), and a second very small foresail (Storm jib). I intended to sail this homespun lash up off to the fabled South Pacific Islands, and I wasn’t daunted the first time I flipped the boat over off Marina Del Rey in Southern California. I figured I’d just fix the design faults when I rebuilt the broken parts and re-assembled the whole thing. The second time around was better, but not the perfect escape module by any means. I did, however, discover some needs I shared with other builders. I developed and patented a couple of plastic gizmos (an O ring sealed deck plate and a line of plastic port holes). These items were the beginning of Progressive Yacht Hardware International (PYHI). That marine hardware company eventually grew to include dozens of products made of plastic that found use by sailboat, powerboat and jet ski manufacturers.
During the heyday of backyard boat building, boats were even made of cement. The misconception by many of those setting out to home build a boat was that the hull or hulls (catamarans and trimarans) represented the expensive part of a boat. In actuality, the hull represents only about 1/6 of the expense and effort to build a boat. Sails, rigging, engine, lifelines, electronics, keel, rudder, interior furniture, cushions, wiring, plumbing, safety equipment and on and on were the realistic expenses that shocked many dreamers, killed budgets and stalled out many a project.
The First Production Fiberglass Boat Building Companies Spring Up
As with all Capitalistic societies, where there was innovation, there were individuals trying to monetize it. Boat builders, some not so great, and some so great that their boats are still revered today, began to take their molds for fiberglass boats and form companies.
Boat building companies were springing up like weeds. It was magnificent.
With this new industry came some surprising changes:
1. You could now buy a boat, designed by experienced designers, and manufactured professionally by trained builders, for nearly the same cost that you could build your boat for, maybe a little more.
2. Due to this new found access to boats, it opened the doors for many would-be sailors to make the plunge - and consequently the number of docked boats in marinas shot up dramatically.
3. As the decades went by, the numbers of these boats didn’t decrease, and boat owners weren’t forced to buy new boats. Fiberglass, for the most part, didn’t sit and rot or degrade like wooden boats did.
4. A resale market was created by the 1980’s that meant that you could buy a well designed 1960’s or 1970’s boat for far less than you could build one from scratch. This inexpensive resale market didn’t exist before because wooden boats required a lot of maintenance to up-keep, which meant that resale prices were quite high comparatively.
5. Consequently, many of these boat manufacturers had simply run themselves out of business - they couldn’t sell enough new boats, because the old boats were still floating proudly!
The Reason You Probably Don’t Need to Build a Boat
The simple fact is, there are so many used production built fiberglass boats around today that are 10-40 years old and still in very usable condition, that it might make great sense to buy one of these boats at a fraction of what it would cost to build from scratch, and instead invest 25-50% of what it would have cost to build from scratch into a retrofit and save the rest for your cruising kitty.
Think about it, the best designers in the world have designed a boat for you already and she’s floating in a marina somewhere with a for sale sign on her. Could you really do better? Is it worth it?
Now, Why You Should Build a Boat From Scratch
Many talk about “building a boat and sailing around the world”.
If you’ve sailed boats your whole life, know a lot about sailboat design, and most importantly, have never found the exact layout or design you’ve been looking for, you’re probably a good candidate to build a boat.
You should build a boat if you crave a design that hasn’t been built in production or that is impossible to find used (due to low production numbers).
If you lack the knowledge, the hours behind the helm to know what you like or don’t about hull and layout designs, etc. then you should probably think about buying a boat, as mentioned before.
Building a Boat Doesn’t Have to Mean Designing from Scratch
You can very easily pick up plans from noted designers on the internet for hundreds of dollars. Nearly every major designer of the last 30 years has their boat plans posted online, many of models that were never put into production. Its like buying home plans from designers… this is a great place to start with, whether you build exactly to plan or make some small changes.
That said, if you’re planning on making a lot of changes, it might be best to start a whole new set of plans to begin with, and use the designed plans as reference.
Just be sure one end of your boat has a point on it.
Construction Materials
I will talk about specific materials in a later post.
However, here are some basic pointers:
WOOD: DO NOT TRY TO BUILD A WOOD BOAT UNLESS YOU KNOW PRECISELY WHAT YOU ARE GETTING INTO. Wood shaping and materials require meticulous craft and care to achieve perfection. Building a wooden boat, as you might know from my other posts, is my least suggested course of action. The upkeep is high, the build costs are high, and it is simply unnecessary in the 21st century given the alternatives. Of course, wooden boats are still probably the prettiest of the bunch, and many skippers have an affinity for them, so if you are thinking of building out of wood, please talk to some wooden boat builders and owners in detail before making a final decision.
PLYWOOD / GLASS: This is most likely the best all-around combination. Provided it is properly assembled and you get no blisters on the glass, this is 90% of what you see in marinas today.
STEEL: Steel is mostly outdated. Of course, it’s strong. I’ve seen a steel boat go through a reef near Moorea, and was pulled back out through the reef with only a couple of dented bilge plates. The reef looked a lot worse. That would have instantly sunk a glassed or wooden boat. The downside of steel is the rust and extreme weight issue.
CEMENT: Great idea, very difficult to properly implement, can degrade over time, very heavy. Also, mostly uninsurable.
ALUMINUM: The real building material of the future for one-off boats. Very strong, lightweight, and easy and quick to build with. It’s also the most expensive of the building materials, and very difficult to form into compound curves.
Now, for MY Plan
To cap off this post, I do have to admit that in spite of my advice to everybody else, I will more than likely BUILD my next boat, out of aluminum. Why am I contradicting my own advice? Well I want to get back to multi hulls (where I started 50+ years ago) because designs, materials (marine grade aluminum) and building techniques have progressed to the point that it is conceivable to weld one up with the skills and tools I already have.
My guesstimate is $60K and 90 days of my labor will get me to a sailaway 36 foot aluminum catamaran with a 20 foot beam. I will cut the pieces and tack them together, leaving the seam welding to a pro. To have this boat built would be at least $250K. I can’t afford that. So on I go, doing my Don Quixote imitation. For me it works, even if it fails. I just love building floating things with one (or two or three) pointy ends and the ability to be my magic carpet……to Shangri-La!
As always, I'd love to hear your thoughts on this!
My Sailing Advice, Tips, Tutorials Blog:
Old 01-20-2009
NOLAsailing's Avatar
NOLAsailing is on a distinguished road
Don't you know that boats are expensive?
(Good post - thanks)
-Jason
Old 01-20-2009
I made (had it made) my own boat.
Old 01-20-2009
tommays's Avatar
tommays is on a distinguished road
The 36' Northern Lights next to my friends boat is a piece of work BUT it took the family 12 years to build it and they really worked hard at it
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 01-20-2009
LittleWingCA is on a distinguished road
I am surprised kit boat building isn't all that strong. The kit plane market seams to be healthy. Why not just buy a FG hull, deck, and liner module and put it together yourself with you doing all the mechanical, woodworking, and plumbing? I believe some early Flickas came that way. Why not now? Is the bulk of the labor just in laying up the glass? If I can buy a all metal plane kit and just spend 500 hours riveting it together, why not take a pre-made hull, deck, and liner module, poured keel, and do the rest? Can't be all that hard to put one together.
LittleWingCA
1980 Pacific Seacraft Orion 27
Sailing Grounds: Southern California
Old 01-20-2009
WouldaShoulda's Avatar
AEOLUS II
WouldaShoulda is on a distinguished road
My Uncle built a small power cruiser, must have been almost 40 years ago. He owned it a few years and sold it when he traded up.
A neighbor was building a ferro-cement sailing vessel during this same time.
That hull is still in his yard!!
Old 01-20-2009
A lot of custom boat building is still being done. Many multihulls are one-offs. Farrier, Kelsall, Cross and several others have sold a lot of plans over the past twenty years.
Old 01-20-2009
camaraderie's Avatar
moderate?
Hey...no need to start from Scratch Capn'...David Vann has one that only need a "little work"!
Old 01-20-2009
deniseO30's Avatar
Lies about her age
To ask the OP's question on the wooden boat forum would be dangerous! I love boats, and wooden boats in particular, but realized many years ago I'd have to concertrate my wish to build on small boats only. I found myself building clear fiberglass strip canoes. After 5 of those I got tired of the sticky stuff and started applying my efforts to restoring traditionally built wood canvas canoes. Then a couple of plywood kayaks, and a one off 15ft wood canvas canoe of my own design. Then bought an old house. That pretty much put my love for wooden boats on hold.
If someone were really really that in love with building a boat there are hundreds (maybe thousands) in barns, yards, garages that have never been finished! Then of course restoration of a boat always makes sense too. There are lists and organizations like "wooden boat rescue , good old boat, and bone yard boats". I still think the best thing to do is find a fiberglass boat that needs TLC. My oday gets a few wood items fixed or changed every year. It quells the nagging wish to have a "real wooden boat"
I did sell off my 9ft plastic dinghy with the intent of building my next dink. It's going to be a 12 ft "semi dory" I may make it 11 ft though. I'll be using marine plywood for the "strakes" (planks that look like house siding) steam bent ribs and a mahogany transom. Maybe even a dagger board and sail rig!
why? because I love wooden boats! if you don't know that feeling I could never impart the passion upon you! I could buy one cheaper for sure. You can say I am building my next boat! her name will be be " A lil keeled over"
Old 01-20-2009
blt2ski's Avatar
here you go 30 yrs later, still not splashed, this trip was two yrs ago, was to go in last yr, maybe this year. Step dad is now in his mid 80's, 2 hip replacements later, one knee replacement, I hope he is able to sail it once before he goes away. Not my type of boat. If he was working on a T-bird..........maybe.
Not sure it is worth building one yourself, other than to say you did it, yes been there done that with an 8' pram, and typical 12' sloop rig as a teen in plywood from Glen-L plans. I may build a dingy again, to sail in a small lake near me, probably an El Toro if I can verify a local fleet is availible to race against. other wise, not sure why?
marty
She drives me boat,
I drives me dinghy!
Making Passage w/o a Rudder wind_magic Seamanship 60 07-16-2010 02:23 PM
Life in the fast lane, well for one day at least... Lancer28 Learning to Sail 8 11-27-2007 11:36 PM
Coastal v. Bluewater cruiser, your thoughts EveningStar Sailboat Design and Construction 17 11-02-2007 07:13 PM
Naming and Renaming Your Boat Sue & Larry Cruising Articles 0 12-15-2003 08:00 PM
Refitting an Older Boat Sue & Larry Gear and Maintenance Articles 0 12-16-2000 08:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
