Jumper Struts? - SailNet Community
post #1 of 8 Old 08-12-2009 Thread Starter
Once known as Hartley18
Classic30's Avatar
Dock
Jumper Struts?
I've been away for a bit - busy with work, etc., etc. but with A-S "temporarily off-line" I thought I'd ask this question here:
A boat we're looking at upgrading into is rigged with the old-style(?) jumper-strut set-up:
Stuff I've read is neither good nor bad - so, has anyone here got any experience this system?
Apart from requiring a haul up the mast to tweak (and exactly how do you 'tweak' it?), is there anything particularly wrong with this setup??
Thanks,
Classic30 is offline
post #2 of 8 Old 08-12-2009
Ilenart's Avatar
Hi Hartley18. Long time no hear. Does this mean you will be changing your Sailnet name?
Sorry can't help with your question, apart that is looks more complicated than a normal rig and not being able to adjust from the deck would be a pain. What sort of boat are you looking at?
Ilenart
Ilenart is offline
post #3 of 8 Old 08-13-2009
ASA and PSIA Instructor
My suspicion is the jumper struts don't matter much, nor need much tune if any, especially if you don't lay on the backstay adjuster.
R19s were designed with jumper struts but most racing boats have removed them striving to reduce weight and windage aloft.
sailingfool is online now
post #4 of 8 Old 08-13-2009 Thread Starter
Classic30's Avatar
Dock
Hi Ilenart!
I'm spending most of my (limited) time at Anything-Sailing nowadays - but we'll be keeping the Hartley for now. I've spent way too much money on her lately, including a new #2 just recently!!
It's a Folkboat - and it's got everything I like: 26'-ish, wood, fractional rig..
More here: Something we're looking at.. - Anything Sailing Forums
Thanks both for your replies - I get the impression jumper struts are not something I need overly worry about.
If A-S goes down again - I'll be back!
Cheers,
post #5 of 8 Old 08-14-2009
Moderator
Jeff_H's Avatar
I had a 1949 wooden folkboat with jumper struts. They were important for controling headstay tension, masthead sag in a breeze. In effect they transfer the aftward force of the backstay to the forestay and eliminate the need for swept back spreaders or for running backstays on early fractional riggers. The are mostly out of the way except that jumper shrouds can hit the leech of the chute when close reaching.
I found that they were pretty much a set them once and leave them affair. You typically wanted just enough tension that the mast was straight vertically and side to side with minimal backstay tension. They bascally proportionately self tension as backstay tension increases.
Jeff_H is online now
post #6 of 8 Old 08-14-2009
tdw
Super Fuzzy Moderator
tdw's Avatar
My first keeler was a Bluebird, 22'er 7/8ths fractional similar to the Folkboat with the jumpers. I certainly never found the need to adjust them and yep as Jeff says they rid you of the need for runners.
They are not something that you'd need to worry yourself about.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #7 of 8 Old 08-24-2009
JimsCAL's Avatar
The Pearson Triton had them. As JeffH notes, found on older fractional rigged boats.
JimsCAL is offline
post #8 of 8 Old 08-24-2009
Gary M's Avatar
I had a 26 foot fractional rigged boat, a Niagara 26 that originaly had swept back spreads, about 25 degrees. I could not get proper tension on the forestay unless the uppers were extremely tight all the time. I modified the rig so that the spreaders were only swept back about 5 degrees and installed jumper struts. Best move I ever made with that boat.
The jumper struts really stiffened up the top section of the mast so that the back stay adjustment worked much like a mast head rig when it came to tensioning the forestay and when it was eased for down wind the forestay was slack.
I raced and it made a huge improvement. Struts are not common any more but I liked them.
Gary
Gary M is offline
Reaching struts dpboatnut Racing 16 03-10-2013 09:37 PM
Barnacles, Props & Struts 7Psych Gear & Maintenance 9 10-14-2007 01:52 PM
