parallel sails? - Page 2 - SailNet Community
post #11 of 24 Old 01-15-2010 Thread Starter
Ok, wow, now for the application question.
I'm looking at making a "mothership" rig to use to bring my kayak out to the (California Channel) Islands. the idea was to start with the clc sailrig ( Kayak & Canoe Sailing Rig: Ultra-Light, Easy to Assemble and Launch! ) or at least the ama's, except I'd really like to create a vessel which I could
a.) reef or drop sail
b.) detach the kayak from the rig while at sea, if I decided to anchor it somewhere where there wasn't a convenient beach, so I could paddle around.
c.) where the entire rig, including kayak is still cartopable
and of course, having a boat that I'll be building, play with weird sail designs and other ideas, just to see what works.
To make this as unburdonsome to the kayak as possible, I'm hoping to run all lines down the aka's, and basically give myself a control console. it's got a 10' beam, so I think it's wide enough to give me the clear channel I need. I'm also pondering if reefing is necessary, or if I could just use windsurfer sails and masts (with a mast step to hold them upright) and just turn them out of the wind to varying degrees to cut the effect of the wind.
This year it's just brainstorming, as I've not finished the kayak yet, let alone started on the ama's, but I thought it was an interesting design idea, and one which might be applicable for such a craft.
Thanks for all the info
-- James
jbarros is offline
post #12 of 24 Old 01-15-2010
nickmerc's Avatar
You could still have a mother ship with onlt one mast. Just mount the mast step on one of the amas.
Or, you could modify a beach cat to be your mother ship.
________
DivineSmile cam
nickmerc is offline
post #13 of 24 Old 01-15-2010
mitiempo's Avatar
I paddled a Feathercraft in Baja twice and some days wished for a sail. Here are a few examples. The one I like is the first on the Nautiraid. But the second one looks cool.
Brian
mitiempo is online now
post #14 of 24 Old 01-15-2010 Thread Starter
There are a number of awesome kayak sails, (your awesomeness may vary) I'm looking to minimize my impact on the kayak itself, which eliminates most of them, and I'd like it to sail well, even upwind, which eliminates all the rest.
What I was looking at with the clc kit was similar to modifying a beach cat, perhaps just taking one of those apart would be the hot tip, although I'm curious about how much work it would take to cartop one.
Thanks.
-- James
jbarros is offline
post #15 of 24 Old 01-15-2010
mitiempo's Avatar
I see. You don't want to paddle at all.
Brian
post #16 of 24 Old 01-15-2010
nickmerc's Avatar
You will probably not be able to cartop a beach cat. I used to tow my Hobie 16 with a VW Passat. The boat was wider than my car. They are also unwiedly to move around solo when not in the water.
________
Volcano Vaporizer
nickmerc is offline
post #17 of 24 Old 01-15-2010
mitiempo's Avatar
If the amas are removeable it should be possible. That would leave you with a kayak and two smaller hulls. And a mast.
Brian
post #18 of 24 Old 01-15-2010
AdamLein's Avatar
tager: I looked up DDWFTTW and it looks like they're not sailing. i.e. they are propelled neither by an air drag force (downwind sailing) nor by lift forces (upwind sailing). Instead they have an air turbine powering either wheels (for land vehicles) or a propeller.
I'm think it's impossible to sail dead downwind faster than the wind, which means that going DDW in a trifoiler you're not close hauled, which means that your argument - that there should be some angle at which the apparent wind is abeam - still holds.
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #19 of 24 Old 01-15-2010
This is essentially correct. It also describes the interesting shape of the sail polar diagram of these really fast boats.
When sailing dead downwind, you are using the drag of the sails in the air and no lift is being generated (I am ignoring unstayed masts where the sails can be let out further than perpendicular). Therefore, even with infinite drag (roughly proportional to sail area), you still can't outrun the wind. On other points of sail, you use lift rather than drag which allows you to sail faster than the true wind speed. In addition, since you are not pointing in the same direction as the wind, the apparent wind moves forward which explains why the boats always seem to be close hauled. Since these boats are so fast broad reaching, they will tack downwind because it is much faster than running. To see why this is the case given the polar diagram, take a ruler and hold it perpendicular to the true wind direction and slide it in towards the center until you hit the line. On these fast boats, you will hit two points first for going with the wind which correspond to broad reaching on each tack.
klem is offline
post #20 of 24 Old 01-15-2010
mitiempo's Avatar
That's right. They start broad reaching and as they pick up speed the apparent wind moves forward of the beam. The tri-foilers move through this stage quickly. The faster they go the more close hauled they are. They tack downwind and even though they cover a greater distance their vmg is better. The tri-foilers in the video never slow down enough for the apparent wind to come aft even when changing direction as they lose very little speed.
Brian
Yawl Info Needed sailortonyb1 Boat Review and Purchase Forum 5 01-18-2006 04:51 AM
The Balance of Hull and Sails Steve Colgate Learning to Sail Articles 0 05-25-2000 08:00 PM
The Balance of Hull and Sails Steve Colgate Seamanship Articles 0 05-25-2000 08:00 PM
