Komatex® - Expanded PVC Sheet - SailNet Community
post #1 of 2 Old 01-15-2010 Thread Starter
Tundra Down
downeast450's Avatar
I am considering the use of Komatex® - Expanded PVC Sheet as a headliner. One consideration is the distance between the trim strips that hold the PVC in place. I have not used Komatex® - Expanded PVC Sheet and am wondering how thick the material will need to be to span 12", 18" or 24" for a 96" run?
Down
downeast450 is offline
post #2 of 2 Old 01-15-2010
It depends... is the material going to be supporting just itself? Also, is the material going to be a flat panel or a curved panel. A curved panel will often need fewer trim strips to hold it in place properly, since the curvature of the panel will often provide the panel significant support—this is why most steel tape measure blades are curved...
sailingdog is offline
Trimming Your Asymmetrical Spinnaker sandygoodall Seamanship Articles 14 03-31-2010 09:27 AM
Reading Flow and Making Adjustments Tom Wood Learning to Sail Articles 0 09-23-1999 08:00 PM
Reading Flow and Making Adjustments Tom Wood Seamanship Articles 0 09-23-1999 08:00 PM
Reading Flow and Making Adjustments Tom Wood Gear and Maintenance Articles 0 09-23-1999 08:00 PM
Reading Flow and Making Adjustments Tom Wood Cruising Articles 0 09-23-1999 08:00 PM
