Go Back   SailNet Community > General Interest Forums > Boat Review and Purchase Forum > Sailboat Design and Construction
Old 02-21-2010
nemier is on a distinguished road
most environmental conscious construction?
Please forgive me if this has been discussed previously.
What type of boat construction is the most environmentally friendly?
grp, wood, composite, cold molded, steel, aluminum, carbon fibre, etc, etc
Your thoughts??
Old 02-21-2010
Define environmentally friendly? Do you mean which boat causes the least in carbon emissions? Do you mean which boat is most easily recyclable? Do you mean which boat is biodegradeable and will not leave long-lasting remnants behind when it is disposed of?
Your question is so broad as to be basically unanswerable IMHO.
Old 02-21-2010
danjarch's Avatar
Siren 17
danjarch will become famous soon enough
You can add in whether the boat is produced by a big production boat company, is a one off design built by a professional or is built by an ameture.
!! WARNING !! The above information is to be used by intelligent people only. If you are Stupid, could be considered a moron, or otherwise. You are instructed to disregard this information and seek the help of a licensed and bonded professional.
Old 02-21-2010
Allanbc's Avatar
Allanbc is on a distinguished road
Maybe it was that boat built our of plastic bottles, AKA the Junk Raft, that sailed from California to Hawaii. On the other hand, they lost a bunch of the bottles on the way so it might not count.
"When in command, command." -- Admiral Nimitz
Difference between a power boater and a sailor out on the water: A power boater is going some place special, a sailor is already there.
s/v Zotz 1981 Pearson 365 Ketch Hull #375
Old 02-21-2010
Dog & Danjarch,
I mean all of what you say. Encompass all of it.
I want to know which sailboat construction will leave the least "environmental" impact on our wonderful world, all factors combined.
For some reason which I can't expalin, this is suddenly important to me.
I will be purchasing a sailboat in the very near future and would like to consider God's creation - our world (better late than never)
What say you Dude?
Old 02-21-2010
Nemier—
As I said in my reply above... your question is so vague as to be unanswerable. The variables between the different construction methods and materials required for building a sailboat using them makes defining which is the most environmentally friendly very difficult. For instance, building a steel sailboat requires that you mine, refine and manufacture steel plates to make the hull. Can you really say that this is more or less environmentally friendly than cutting down trees and shaving them into the thin strips that would be required for making a cold-molded wooden boat or the manufacturing processes for making the fiberglass and resin used in a GRP boat?
Assuming all the boats are roughly the same size and use the same common components—winches, spars, line, etc...so that the only difference in them is the hull and the construction methods and materials used to build the hull... you'd still have far too many variables to say which is the least environmentally damaging. For instance... is the steel virgin steel or recycled? Recycled steel is far less damaging to the environment, but often less useful since it can have contaminants, like copper, in the alloy that make it less suitable for specific uses.
Old 02-21-2010
Part of the solution
bljones has a spectacular aura about bljones has a spectacular aura about
papier mache using recycled newspaper and biodegradable paste, construct frames, knees, stringers and decking from reclaimed lumber from dead chris-crafts and trojans.
Old 02-21-2010
Architeuthis is on a distinguished road
The one not built.
Otherwise it is the one built with the least amount of energy, likely wood if new. If you want to use trash use sheets of Aluminum, left over from larger construction jobs. Call it recycling or reusing and then you can feel good about it.
Old 02-21-2010
Large Member
mdbee is on a distinguished road
How many people really care? Sorry, although I believe in keeping the environment clean, I'm not going to put my money in some POS just because some left wing wacko in LA or SF thinks it's the "environmental" thing to buy.
Maybe sticking a mast on a stinkpot and removing the twin engines would be the best answer to your question.
Your thoughts??
Old 02-21-2010
Large Member
Sorry
I should go out and watch "Avatar" and then go hug one of the trees in my backyard. I'm not sure what came over me.
Really need to get out of the house....
Global Warming Debate HoffaLives Off Topic 4227 2 Weeks Ago 12:07 PM
plywood-epoxy construction amunk Gear & Maintenance 4 02-23-2005 10:55 AM
plywood-epoxy construction amunk General Discussion (sailing related) 1 02-15-2005 02:03 PM
Hull Construction Questions Dan Dickison Gear and Maintenance Articles 0 01-15-2001 07:00 PM
