- Quick Menu
03-18-2010
Head Location?
Well, the count down to debt free continues, and the horrible ideas for changing perfectly good boats (none of which I own at present) keep popping up.
So, I was thinking about the location of the head. On most modern boats it seems to be farther aft, just next to the companionway, and is larger than on older boats, a nice touch if you're old at heart and think of things like onboard hot water showers as less of a luxury and more of a necessity.
So the first question I have is about the trade offs involved. I know in older, narrower designs there just isn't space for the same luxurious head compartments, which sometimes have over 4 square feet of room. Almost enough to turn around in  But aside from the trade off of being able to put whatever they put by the companionway instead (chart table, galley, etc) is there any advantage to having the head up by the mast step instead of back by the companionway?
If not, my second question gets a lot dumber. Given an older boat which needs work anyway, how stupid would I have to be to think about building out a head compartment aft, near the companionway, and just converting the forward head area to another locker? On a small boat (30'ish) where space is at a premium, it doesn't seem like the wisest idea, but damn it, it would create just enough room to actually take a shower while standing up, and with the head on one side and the galley on the other, puts the most used parts of the boat closest to the companionway, and means that if the table is down, and blocking the path forward, it will still be easy to get to from the cockpit.
Aside from the insanity of the act of a "remodel" (?) of the interior of a boat, what stupidity am I, theoretically of course, getting myself into that a real boat designer chose not to do?
Thanks.
-- James
03-18-2010
It really depends on the boat. Some boats just aren't really capable of having a head aft. If you want a boat with an aft head, you're really better off BUYING A BOAT with the head aft...
Re-arranging the interior of the boat will generally require the services of a marine architect, as moving or adding bulkheads to a boat can do strange things to the structure. It will kill the boat' resale value.
03-18-2010
Moderator
I pretty well agree with SD -- Yes, it can be done, but if that's what you're looking for, why not target a boat that's already configured in that way?
Then again, if you relish that sort of challenge, go for it. If so, look for a boat that is "stick built", i.e. one that does not have structural fibreglass pans as part of the interior build out.
One thing to keep in mind, though: With boats in that size range that are originally configured with an aft head, the remainder of the interior is usually adjusted forward to provide adequate main salon accommodations. In other words, the space that might have been occupied by the forward head, is instead used by the main salon. This is how they make up for the space that has been "lost" farther aft.
So you could end up making many more adjustments than simply adding an aft head and converting the forward head to stowage. And that's where you begin to need the advice of a marine architect, as mentioned above.
03-18-2010
Best Looking Moderator
A head that is or about midship will be ok - but the heads further aft are preferred for offshore in my opinion. For example, and this is noooo exhageration:
We have two heads on the boat - one aft and one forward. At one point, I went forward to use the forward head as dad was in aft. Now, we were in some pretty good seas, and we were 'jumping off of them', however, I would literally come off my feet each time the seas went under us. I mean airborne and hit my head on the cabin top. As such, the forward head was completely un-useable in those conditions. Those types of conditions, though not commonplace, will and do happen offshore more than the magazines tell you.
Get an aft head configuration for offshore work. Anything forward or much forward of the mast becomes worthless in larger seas. And if you are remotely prone to sea sickness... forget it. You are better off with a bucket and Little John.
Regarding rebuilding your own head - don't even go there. Many of those things may be structural. THis is not a house. Plus, the cost involved would be more than if you just bought the right boat in the first place.
My opinions.
Brian
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Are you trying to talk your spouse or family into cruising or sailing? Want to know what it is like, every day? Click here and enjoy: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
03-18-2010
Have to agree with the above... simply 'moving' the head will be anything but simple - and lead to an oddity with other drawbacks as a result.
If you can't find anything on the market that suits you and you have the 'itch' to be creative that way, a bare hull might be a good starting point... then you can engineer/place bulkheads and arrange the interior to what suits you. Having said that, though, unless you've owned a few boats along the way you may not truly have a strong sense of what will work and what might not. This could lead to another expensive, odd duck with re-sale challenges.
1984 Fast/Nicholson 345
03-18-2010
Thanks for the unanimous advice.
Right now I'm just digging myself out of debt and trying to save up, hoping I'll have the ships bells to buy a boat and go once I'm debt free. (18 more months) Because of my situation, I'm looking in the 20k and under range, which is rather insanely low for a real cruising boat, but the Tartan 30 and Pearson Triton both have a number of models in range, the Tartan even has the possibility of a shower. I've been looking for Cape Dory 25d's but can't find a one in my price range. I've also not sailed on a CD25d, whereas I've been able to find people who took me out on Tritons and Tartan 30's and had a great time. Fun boats.
CruisingDad, While the heads on the boats I'm looking at are "forward" as opposed to by the companionway, with the exception of the CD, their aft bulkheads are right under the mast. This seems to be a really popular configuration in earlier boats, I'm presuming because the rules of the day rewarded skinny boats with low waterline lengths that wouldn't have the extra beam farther back like the modern boats?
I found it hilarious, in a sad way, that the one boat which seemed willing to dedicate some space to "personal maintenance" puts it so far into the forepeak that I can only imagine it's all but useless while under way.
Anyway, for the sucker who wants a hot water shower, and wants one on a boat he can get for next to nothing ($20k or less goal) what is the hot tip?
I've sailed a few Tritons (west coast) and I like them. I'm sure it's a sign of my own inexperience, but a small boat like the Triton makes me feel more confident when docking, etc. Also, since they seem to be found in decent condition for $10k-ish, that gives me more money to fix/customize etc.
I was looking at just putting in a shower, and while the drainage, pressure water, heater, etc are all big space issues, (doubly so on a small boat) but even if I did all of those, on, eg, a Triton, there's not room to stand up and turn around, not even in that "on a boat" sense.
Technically I think I can do the hardware installs, but the question of having room to shower is more "interesting".  I thought "moving" it aft would solve this, as well as place it in a more convenient space, but from the looks of it, this would turn into way more project then I want.
Regarding the shower (And actually having room to shower)
I've decided long ago that I really need to decide what makes and breaks my own comfort when I'm doing things, and if that's what keeps me awake, alert, and happy, then my trips going to be safer and better all around. This is why I have good boots, this is why I carry more bedding in alpine environments than weight would dictate, and I'm happy with my choices in that front. Is this still practical on THIS front?
At this point it looks like my question really becomes how much do I care about having room to take a belowdecks shower, and can I do it in my price range without sacraficing seaworthiness?
The answer may be a bigger budget for a boat, but that scares me too, as every time the budget goes up, the "departure" date goes back.
Thanks for the advice. My search continues
-- James
03-18-2010
Moderator
-- James
James,
From my perspective, the answer IS a bigger budget. During the time it would take you to retrofit/shoehorn a dedicated aft head with shower into a small boat not originally designed for one, you could easily keep working at whatever you do a bit longer and save money to buy a more suitable boat. The way a lot of these refit projects go -- you might even shove off sooner.
As for the shower -- you might be overthinking this, or at least misplacing your priorities. I will tell you that our 31 footer has an aft head with combination shower (not a dedicated stall, but the head doubles as a shower.) We also have a cockpit shower. We use the cockpit shower far more often. So there are alternatives....
Also, while we have an aft head, and I prefer that arrangment, I wouldn't get too hung up on this requirement. It will really limit your options when looking for boats in your price/size range. For instance, since you mentioned Cape Dorys, the CD30Mk2 is a lot of boat for the money, and maybe worth saving your nickels for. Although not an aft head it does have a shower....
Cape Dory 30 Mark 2
03-18-2010
Thank you again. ok, well, for now the gameplan is the same. Keep working, live low to the ground, put money in savings.
03-18-2010
Sounds like a good overall plan, no matter what your timetable is.
"There's nothing . . . absolutely nothing . . . half so much worth doing as simply messing around in boats." -- Kenneth Grahame, The Wind in the Willows (River Rat to Mole)
1980 Baba 35 Pilot House Cutter - Brigadoon
03-18-2010
Some 30' boats had a pretty decent head aft... like the O'Day 302.
The only real problem with the O'Day 302 is that you'd be sailing the same boat as Denby... and that might be a problem... especially if you've ever met him.
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Updating Your Head
Sue & Larry |
Gear and Maintenance Articles |
0 |
12-25-2002 07:00 PM |
Head Problems
bootsy1962 |
General Discussion (sailing related) |
3 |
02-19-2002 07:26 PM |
Head Maintenance Blues
Tom Wood |
0 |
11-21-1999 07:00 PM |
Tom Wood |
Her Sailnet Articles |
0 |
