07-05-2010
Senior Slacker
You might note that one doesn't need to add enough floatation to compensate for the entire displacement of the boat. A 6000# boat will likely have 2000# to 3000# of metal (ballast, fittings, etc.); the rest is going to be pretty much neutrally buoyant (fiberglass, wood, etc.). One only has to worry about the negatively buoyant metal. So, to keep a 6000# boat from sinking, one really only has to provide about 2000# to 3000# of positive buoyancy (plus a bit to keep it from being too close to neutrally buoyant). However, using 2500# as an example, one would still need more than 550 2-liter bottles to keep it afloat. Given that no matter how careful one is about packing such bottles there will still be quite a bit of unsealed space between them, bundles of closed-cell foam might be a better (if somewhat more expensive) way to go about such a project.
