Cored Hulls and Decks - Page 2 - SailNet Community
post #11 of 59 Old 10-18-2010
Originally Posted by sailingfool View Post
Sure cored hulls have advantages, and are de rigueur in race boats, and are best when done "properly" by a high end builder. But I think you err if you believe that a "properly" built cored hull is immune to someday getting wet due to the vagaries and challenges of getting old. And if that someday comes to you as the owner, you face a repair bill that makes the cost of popping in a new engine look like chump change.
Well, I tend to look at things over my perspective. I am interested in new boats, or relatively new boats, and as many guys, I would change my boat after 10 or 15 years for more performant boat and a boat that give me no maintenance problem. Many sailors in Europe change boats each 4 (to 7) years.
For these ones, a well made cored hull would not mean any problem. Not for them not for the second buyer of that boat. You say that at a very long term (20 or 30 years) the hull would have more problems than a solid fiberglass hull? Yes I probably agree, but I don't care. Anyway at that stage the value of the boat would be a very small fraction of its initial price.
post #12 of 59 Old 10-18-2010
tommays's Avatar
Well
As i have drill a few holes in Jboats
That 4 MM on the left is the OUTER-SKIN and the nice thick one is the inner
The chunks on the far left are from a J160 that fell over and landed on a pile of OPEN jackstands
Having the quest to learn i went over and pull out the 50K core samples the stands had taken and i can assure you the outer skin on a BIG Jboat is NOT all that thick just thicker balsa
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #13 of 59 Old 10-18-2010
Best Looking MALE Mod
Cruisingdad's Avatar
Again, I say in cruising boat or performance cruising boat, why bother? And there is absolutely nothing wrong with grids and liners.
And as for you, T37 chef, my momma could be put on a Farr 40 and my kids could beat her in the Compaq. I can't help it if the guy didn't know how to sail!!!! Most of the people that can't sail buy Telstars. Maybe he was motoring to the Telstar dealer??
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #14 of 59 Old 10-18-2010
CD—
BITE ME!!! I can't believe I'm getting talk like this from a cross-dressing bbq grill detonating Catalina owner...
sailingdog is offline
post #15 of 59 Old 10-18-2010
No comment.
smackdaddy is offline
post #16 of 59 Old 10-18-2010
Again, I say in cruising boat or performance cruising boat, why bother? And there is absolutely nothing wrong with grids and liners...
Brian
Brian,
Because comparing two exactly equal boats, one with cored hulls, the other with solid fiberglass hull, the cored one would not only sail better as it would be a safer boat, with a far better overall stability. Progress is that. Builders make the boats, the best they can, for a given budget. If they can make a better boat, why should they make a worst one?
That's the same thing with injection and infusion technics. Why bother? Because with them they can make better sailing boats
post #17 of 59 Old 10-18-2010
T37Chef's Avatar
This si why Catalinas are begginer boats I suppose hehehehe (yes I tyoed it like that so youo could understand it CD)
Shawn
T37Chef is offline
post #18 of 59 Old 10-18-2010
Hey Paulo, like I said, Catalina (I am just using them as an example) and I discussed this Friday. THeir reasoning was not cost, but to have solid glass under the waterline in the event of a hard grounding. They prefer the bulk. In a perfect world where no one hits anything, I see your argument and agree. But I run aground all the time and want solid glass below the water.
You made the case that it is a cost issue and I dissagree. Here are some other boats that use solid glass:
Taswell
Tayana
Hylas
Not sure, but I think Hallberg-Rassy?? I do know they also use a grid system and think it is a hand laid solid GRP.
It is a philisophical decision based upon use (in my opinion), not cost. However, coring is a more expensive process especially when using divinycell, etc. It is a better process for high performance. I just don't think it is the right process for all boats depending on intended use.
Again, just my opinion.
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
post #19 of 59 Old 10-18-2010
T37Chef's Avatar
Brian
and, case in point
Shawn
T37Chef is offline
post #20 of 59 Old 10-18-2010
mitiempo's Avatar
If you run aground the keel should touch, not the hull. If the hull touches you are really aground.
Brian
mitiempo is offline
Cored Hulls Up North? redstripesailor Living Aboard 5 07-31-2008 01:16 AM
Cored hulls and logs ArgleBargle Boat Review and Purchase Forum 1 05-04-2007 02:29 PM
Airex Cored Decks CBinVA Boat Review and Purchase Forum 4 08-06-2006 10:07 PM
Are Col hulls cored? mrb2222 Boat Review and Purchase Forum 4 01-08-2002 03:59 AM
Cored Hulls Jon Shattuck Gear and Maintenance Articles 0 10-03-2000 08:00 PM
