02-11-2011
I don't believe this is the case. I have yet to see a higher performance multihull or a high performance monohull that has been fitted with a windvane. All of these seem to use autopilots. I think it has to do with the changes in apparent wind due to their higher acceleration throwing the vane off.
Originally Posted by mitiempo
A good vane will work with any boat that can be balanced under sail. I have yet to talk to an owner with a Monitor or other good vane that didn't work well, full keel like Alberg 30, 35 etc or fin keel. I have a neighbor with a 35' Cheoy Lee from the 60s (all teak full keel) and he uses an original Haslar vane without a problem - and the Haslar isn't a powerful vane by modern standards.
I think there are changes that are relatively easy to make to any boat such as leading lines aft, adding a vane, adding more cockpit drains, adding a Solent stay etc.
There are other changes that make no sense. These include opening the transom or any major hull/keel/rudder modification.
Best to pick a boat that has all your major desires in place and only change the less major ones.
